Results 1 to 17 of 17
Thread: T5 conversion for VP
    HSV VP clubby 5.0lt 5spd
    Jan 2010
    waikerie, SA
    Default T5 conversion for VP
    Hey all, i've got a t5 for my VP clubsport v8 and was wondering if i have all the parts i need cos ppl have been tellin me different stuff i need etc.i'm gonna give pulling the auto out an putting this in a crack when i've got all the stuff.
    I have.
    gearbox on mount
    new clutch
    manual flywheel
    pedal box
    console etc
    clutch cable
    also some bolts off flywheel etc
    i think i need a wiring loom and a speedo adaptor or something
    any help would be good thanks
    vn v8 berlina
    Dec 2009
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Gearbox Loom
    Manual Computer
    Manual Tailshaft
    That's all i can see missing.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    You wont need a manual computer. The auto one will run it fine without any fault codes!
    Tail shaft can just use the front half from the T5 (assuming this comes with it) and the back half of your normal tailshaft.
    Congrats on converting, you wont regret it
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Dose it makes a difference changing the computer? Or don't bother.
    Related question here, is the V6 and V8 manual tail shafts the same?
    The Daily VN T5V6
    355 VN GRP A REP
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by mischa View Post
    There no need to, but it wont make a difference which way you got (only in later models like VS).
    Can't tell you the tailshaft differences, both mine are V8s, and the conversion kit i bought was from an SS, so all V8 gear. You wouldn't want to use a V6 T5 anyway (plus they aren't a straight bolt up, needs a different input shaft or something)
    cheers sexy
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Oh I wouldn't use a V6 box, just the fact i can get a V8 box but not a tail shaft to match i wanted to know if I could use one out of a manual V6.
    Yeah to use the V6 you need the V8 input shaft and bell housing.
    The Daily VN T5V6
    355 VN GRP A REP
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Chirpstr's Avatar
    Sep 2007
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    That's good, will only need a V8 box, bell housing, flywheel and clutch then for my conversion.
    The Daily VN T5V6
    355 VN GRP A REP
    Jan 2010
    waikerie, SA
    cheers guys ive got a tailshaft now but the wiring loom is missing.. what wont work if it isn't on there strait away? can you still drive it or?
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VP-CLUBBY View Post
    Yeah will still drive, you just wont have a working speedo. Revs, and all the other gauges will work fine tho. Have a look in the manual conversion thread, i'm pretty sure i saw a way to make a cheap connection for the speedo sender
    cheers sexy
    Jan 2010
    waikerie, SA
    cheers stealthy, i'l have a look for the thread. once thats sorted it should all be there, ready for the conversion then?? cant wait lol
    car
    Jul 2006
    greensy, melb
    if the speedo is not hooked up the car will just keep on stalling, you will be able to drive it but you will have to hold the revs up everytime you come to a stop.
    "A life lived in fear is a life half lived"
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by kniever View Post
    Can't say i've ever had that problem when the speedo wasn't hooked up. I DID have erratic idle (but with the speedo hooked up properly) but that was something different....
    cheers sexy
  16. #16
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by STEALTHY™ View Post
    when i 1st did my conversion my speedo wasnt hooked up for a few days as i didnt have the extension and every set of lights it would stall unless i held the revs up, i couldnt work out what it was as i went over everything until dr bob said speedo, so i immediately got the extension and hooked up the speedo and the car was perfect
  17. #17
    Jan 2010
    waikerie, SA
    ok thanks.. so i've had a look through the forums but cant find anything saying how to 'make' your own loom to make the speedo and that work.. would i e able to buy it over the counter anywhere??
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. LSD Conversion
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2008, 06:45 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. ABS conversion
    By Kingpin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2006, 01:04 AM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
