Results 1 to 8 of 8
Thread: vn temp prob????
    vr commodore
    Apr 2007
    Default vn temp prob????
    just wonering if i have a temp prob my gauge normally sits quite low when driving but when i stop at light it goes upto the mark on the pic below what could be wrong?
    vr commodore
    Apr 2007
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Does it go any higher?
    You might need a new Thermostat ..And a radiator flush out.
    And you will need to bleed the system from all the air..As air can cause the needle to go up
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    There is a problem there, most probably poor coolant cirulation, maybe a blockage, faulty pump, leaks, clogged radiator, thermo (as stated above..good point), but if it heats up at the lights it means the engine is just relying on the incoming air to cool it, it should really be cooling itself even if it has stopped.
    Cooling issue, time to do some trouble shooting.
    and yes it should not really get to that temp under normal around town driving, it is close to overheating.
    Dan
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Dose the thermo fan come on? Should be around half way up the gauge when it comes on.
    But i had a similar problem way back when i first got my car, the thermostat was stuck open tho not, not closed, allowing the engine to heat up. You could have the opposite problem.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vr commodore
    Apr 2007
    the fan does come on but ive only noticed it when the gauge gets to tha mark and the temp wont go back down to near cool untill i drive like on the highway it will go down a lil but not much also have noticed a water leak i think near the water pump but down the side of the timing cover if that makes any sence?
    VP Exe
    Jan 2010
    when was the last time it was flushed?
    think it cost about $100.00 to get it flushed.
    Also check your hoses, the thermo hose at the front of the engine often leaks or the water pump hose or the radiator hose just near the water pump hose.
    get a manual too... to run some checks on this stuff or take it to get flushed and they will replace the thermo and hoses if needed at a cost.
    First things you have to determine is- "is the coolant circulating the engine properly".
    Turn on your air con too and listen if the fan starts up, also listen if it starts up when the engine starts to rise in temp (it should), (If the fan is stuffed check/replace the relay and or get one from the wreckers, a fan that is)
    cheers
    Dan
    vr commodore
    Apr 2007
    thanks vp commo for some good advice i only have one prob with doing it is that when i push the air con button and have the interior fan on the a/c wont engage its got a rather new compressor in it and ive tested for gas which seems to be in there...ive checked all the fuses and relays but cant seem to get it to engage also i rebuilt the switch and still nothing...but in relation to the temp the car performe awesome today in the heat dint go very high in temp and soon as i started to drive again the temp went down and the fan engages at half way exact.
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  3. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  4. temp prob.
    By puck in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 02:23 PM
