My auto VP almost stalls or does stall if:
Any ideas anyone? I want to check error codes using the ALDL, but I couldn't find the damn thing around the ECU.
- I put it into N when waiting at the lights, it'll almost conk out in D at the next lights
- I force gears 2 or 1
- I have the aircon on for a while then go around a bend or corner
Sounds like you got low engine oil or needs new .. Check the levels mate.
But, heres the basic run down:
Clean Pod/Pannel Filter
New Spark Plugs & leads
Oil change
Clean out ya TB , might be clogged with black stuff![]()
yeah clean you throtle body and reset your base idle, that could be your problem mate.
Hmm okay. I had a feeling it could've been the TB, base idle, or CAS. I guess I'll either find a workshop manual or get a mechanic to have a look at it.
Thanks.
