Results 1 to 6 of 6
Thread: security switch?
    VP SS
    Feb 2010
    Tokoroa, NZ
    Default security switch?
    Has anyone had the same fault?
    Yesterday when driving the motor cut out & wouldnt start. I turned off the security switch & I was off again without any drama's
    I feel the switch is faulty, has anyone bypassed this to keep the system operational?
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by Red VP SS View Post
    Cant say i've ever had that problem in either of my VPs. When i first bought my wagon, i wasn't given the security key, so i just drove around without it until i got one (and the remotes programmed)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VP Toyota Lexcen
    Jan 2007
    Common problem with VPs. I have had three of them that all did the same thing. From memory I think the immobiliser was made by Mongoose.
    I just turned the alarm off using the key in the lock in the front passenger pillar.
    Looked at getting it fixed sometime ago, but was cheaper to have a new immobiliser/central locking kit installed.
    VP SS
    Feb 2010
    Tokoroa, NZ
    Thanks guy's
    I now thonk the problem is with the immobilser
    Do you think it's possible to disconnect the fuel cut out & retain the unit just as central locking as Ive just bought a new remote?
    VP Executive R-spec
    Jan 2005
    VP SS
    Feb 2010
    Tokoroa, NZ
    Thanks Guys, I've replaced the switch & its all going well now
  1. Aftermarket LPG switch linked to Factory LPG Switch??
    By GILLO in forum Electrical Wiring / Questions
    Last Post: 18-01-2010, 03:45 PM
  2. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  3. Engine Cooling Fan Override Switch - Using an A/C Switch
    By Maiku in forum Holden Commodore How-To's
    Last Post: 14-03-2007, 10:59 PM
  4. Security switch
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2007, 04:35 PM
  5. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
