Results 1 to 9 of 9
Thread: Problems With the Petrol Gauge
    vp
    Jul 2005
    Red face Problems With the Petrol Gauge
    Need Advise!!!!!!!
    vp
    Jul 2005
    Hey guys, i start my vp up and the fuel gauge stays at empty after i give a wake on the dash it will flick up to full, after a couple days of use the guage will still read full. Any Ideas???????????
    vp
    Jul 2005
    vp
    Jul 2005
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    Jan 2005
    if you keep posting like that, no-one will help you, just be patient. anyway, it sounds like your average vn-vp commodore. take the guages out and check the connections at the back, the terminals are usually the culprit.
    VT SS 5.7
    Mar 2005
    Goulburn
    hey,
    there is a loose wirer inside or behind the cluster. it happen`s to all well nearly all vns.
    or just pull the cluster out and clean the fuel needle it might have sumthing on it that makes it stick at sertian points
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    go and get some electrical circuit board cleaner, you can actualy spray the whole board, it gets all he crusty stuff out from years of build up.
    Mine used to read empty untill i gave it a good tap then all of a sudden it started to work fine and ive never had the problem again.
    I think my problem was a dry joint that needed a but if help
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    VX SS
    Oct 2004
    Mandurah W.A
    dude 4 posts in 2 minutes.. doin crap like that aint gonna get ppl to help any quicker
    Jul 2005
    Hey where are these circuit boards you have to clean? andthe clusters you can check out how can i get to them?
  1. petrol gauge
    By Greenie in forum General
    Last Post: 08-03-2007, 07:27 PM
  2. petrol & temp gauge
    By vincent49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 08:03 PM
  3. Petrol Gauge
    By mickaitken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 11:01 AM
  4. petrol gauge and fuel economy
    By vroomm in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2005, 05:00 PM
  5. Problems With the Petrol Gauge
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2005, 08:46 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
