The Daily VN T5V6
355 VN GRP A REP
hey mischa its a fairly common thing on the old vn's ive had a couple and they were like yours ?things may also need adjusting to suit were there's gaps???
with my old VN i just put a couple of washers under the top mounts for the headlights to raise them up a bit. worked a treat![]()
when you remove the bonnet the bolts at the back are adjustable to a degree, then there is those little bumpers on the side that are adjustable and the latch is adjustable.
You could try removing the bonnet and refitting it again.
I have done this when replacing bonnets and front guards.
The bolts at the back holding the bonnet on, from memory allow the most adjustment.
Dan
Its not the bonnet, the bonnet lines up perfectly with the guards on both sides, its the light sitting too low.
Thanks levy that's a great idea, any idea what caused it tho? Dodgy repairs?
The Daily VN T5V6
355 VN GRP A REP
has it ever been in a accident before??? id do wat levy said??
