Results 1 to 3 of 3
Thread: vn ss
    vh sle !!!!! is offline 262MANTER
    VH SLE, VB commodore
    Sep 2008
    Default vn ss
    hey all
    question about upgrading the fuel system on a vn ss,
    it has a 90litre twin pump tank and i want to put
    fuel pumps in that will supply an ls1?
    can you convert to single pump??
    if so how and what pump??
    if not which 2 pumps should i use??
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Unrelated, but is that a custom tank? If so, can you email me some pics?
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    If its the factory VN 85 litre tank then it is possible to convert to a sinlge pump setup.
    They might be an easier way, but how I did it was get a VR SS (or any other V8 single pump sender unit or modify yours) sender unit and use that.
    Due to VP onwards having the return line on the sender unit and not the tank, I had to get my return line on the tank cut off and welded up and then re routed the hose in the tank onto the sender unit.
    Fuel pump wise, I went with a Wlabro GSS342 intank pump....good for around 500hp
