Results 1 to 2 of 2
Thread: Weird starting patterns & surging engine when car is at lights
    1991 VN Commodore Executive
    Jan 2009
    Default Weird starting patterns & surging engine when car is at lights
    Sometimes my VN turns over normally (mostly when the engine is warm I've noticed), other times it turns over rapidly or it takes over a second. What could be causing this? Also when I am at the lights, my engine surges slightly every few seconds. A couple of months ago I got my CAS replaced and recently my plugs and leads. Before I got my CAS replaced I did a codes check and I also got an error for my oxygen sensor, would this relate to my issues above?
    vp calais 3800
    Aug 2009
    BRISBANE
    I had a VN that did the same thing ended up being the stepper motor so i gave it a good clean and the problem was fixed.
    Its not my fault it broke
  1. weird noise when starting
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2011, 08:34 AM
  2. Weird Starting Problem....
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2009, 04:55 PM
  3. Weird starting problem
    By 89 vn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2008, 12:59 PM
  4. weird starting issues
    By wdrury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2008, 05:35 PM
  5. weird starting issue
    By bradyboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 08:29 PM
