Results 1 to 11 of 11
Thread: help with motor swap, vr motor into vp
    2011 voodoo thunder ss
    Jan 2009
    Default help with motor swap, vr motor into vp
    hi guys, a mate of mine needs to swap the motor in his vp and has got hold of a vr motor, the main problem were worried about is the cam angle sensor the vr motor has but vp doesnt, so just wondering what would be required to get it running, thanks
    VP Executive R-spec
    Jan 2005
    If you just leave it unplugged then it doesnt exsist, into a VP there's no problem
    Jan 2009
    ok cool, shal start putting it in this weekend and see how it goes, thanks mate
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Quote Originally Posted by greenfoam View Post
    greenfoam, you might remember I just put a VN S1 stock engine and stock ECU into my Hilux that was originally a stock VR and stock ECU. I was thinking of trying the VR ECU with the S1 engine, as the plugs are the same, to see what it drove like. Now this cam angle sensor thing is something I knew nothing about. I also read the cam is different, so is it worth while or a waste of time doing the swap?
    VP Executive R-spec
    Jan 2005
    umm well if the ecu is the same then yours is a manual and the VR manuals never ran the cam sensor anyway :!)
    Apr 2009
    Yor good, thanks for that!
    So is the tune in the VR Man ECU a better one for the VN S1 Auto motor considering the possible different cams?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vr tune has way less timing compared to S1 vn keep it in there
    Apr 2009
    I can live with that!
    It might might explain why my 3 core Hilux diesel radiator does not not cope with the S1 engine and ECU, where there VR and ECU was never a problem.
    This is a real learning curve!
    Thanks guys!
    vs v6 turbo, vn v8 turbo
    May 2009
    tearoha nz
    if you dont have the s1 header tank youll have issues was it you that said you teed into the radiator hose to fit the top bleeder out the manifold thats all well and good it lets the flow happen but all it does is send the trapped air into the radiator to circulate again and again and again and again it never comes out .the vn header tank seperates the air and feeds water back into the engine in its place sort of self bleeding .or do you have the vr manifold on the vn engine thats works with a normal radiator
    May 2009
    tearoha nz
    grr damn auto sign in its actually delcowizzid not plymouth his account never signs out and i allways forget about it LOL
    Apr 2009
    Quote Originally Posted by plymouth_hemi_69 View Post
    Yep Delco, it was me. I still have the tank and will investigate options.
    Cheers.
  1. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  2. vr motor swap
    By blake0182 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 09:00 PM
  3. vr to vs motor swap
    By redvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2007, 09:51 PM
  4. Motor Swap Issues
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 05:57 PM
  5. diy motor swap for vt missing
    By horndog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 08:56 AM
