Results 1 to 3 of 3
Thread: Vn auto problem
    VN Commodore
    Sep 2009
    Default Vn auto problem
    Hi.
    Does anyone know if there is an easy fix for a VN auto that is very slow to select reverse gear when cold ? Drive is quite slow as well but it goes straight into 1st when selected then if I put it in "D" then drive away it changes normally.
    George
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    The auto been serviced recently? might pay to have that done. New filter and fluid should do the trick.
    Btw, an easy fix is never a lasting fix. It'll always come back to bite you.
    VN Commodore
    Sep 2009
    Quote Originally Posted by neet_wagon View Post
    Tried the oil change and filter change. Also tried additives but nothing helped. Someone told me that I could have some "O" rings that have gone hard.
    The auto shops just tell me I need a reconditioned box.
    I was hopping there may be some sort of valve block that could be serviced with the pan off because I don't have the time at the moment to pull the box out.
    George
  1. vs auto problem
    By old8s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 01:52 PM
  2. problem with auto
    By IBSK8N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2009, 08:46 PM
  3. vs ss auto problem
    By tinyinass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2009, 05:37 PM
  4. VR auto problem
    By rodney3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2009, 08:03 PM
  5. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
