ok i mnot very smart when it comes to the injected v8`s, just wondering wat was changed between vn/vp/vr &vs commodore series of the v8? also to confirm they where all 304`s?
Real cars don't power the front wheels, they lift them
They are all basically the same. VN-R are rated at 165kw (at the engine) and VS 168kw (i think the only change was a knock sensor and revised CAI)
Yes they were all 304s. The 5L changed from 308 to 304 midway through the VK range (somewhere in 85)(VK and VL remaining carby, VN onwards EFI) and went right up to the VT Series 1 (not including the stroker motors obviously)
Originally Posted by davway
mate spot on for what i needed to know thank you muchly,
Just quickly before i forget, so the vn/vp/vr v8 gearbox,motor,kframe etc would be the same ? as im wantng to scrap the v6 and snap a v8 in
The auto gearboxes are different (VN/P the same, VR different) but everything else is the same.
no worries thanks mate
Yep everything is exactly the same engine wise apart from the VN's having slight better headers (debatable but probably true), oh and starting on the VS or late VR's the oil cap is yellow![]()
i have a vq sv90 enhanced 5ltr and was rated at 180kw
from a enhanced VQ caprice
its also more than 180 now![]()
More small details...
VS V8 Series I was rated at 165kW, the Series 2 was rated at 168kW due to an 'Over Radiator' cold air intake and reshaped top lid airbox.
The later VS Series 3 (Utes and Statesmans), which was the same as the VT motor had the roller lifters and a higher compression ratio through revised heads.
