Results 1 to 8 of 8
Thread: Vn v6 map sensor need step by step guide to clean
    Jun 2006
    Default Vn v6 map sensor need step by step guide to clean
    I have a vn v6 s1 and I have had a k&n pod filter on it for around 4 or 5 years and I read that the oil can cause problems with idle once oil gets to the mat ..
    I have a slight miss on low idle ... I have replaced .. coilpack/dfi , spark plugs and leads .. cleaned throttle body ...ran injector cleaner and new fuel filter etc
    can this mat sensor cause a miss at low revs ???
    I can say 100% that this map sensor has never been cleaned EVER so I want to clean it and see if it helps..
    can someone please show me photos step by step on how to clean it ...
    The mat sensor sits just about the coolant temp sensor correct ? well its 20 years old so I guess it needs replacing ... any tips ??
    thankyou...
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    I have never cleaned one of those in owning a vp and a vn.
    you can clean you MAT sensor but I wouldnt bother with the MAP sensor.
    Just make sure the hoses are correct and I beleive if you have a gregories you can test your MAP sensor for resistance or somthing.
    cheers
    Dan
    Jun 2006
    Ok so im confused between the map sensor with mat sensor .... so the Mat sensor could cause a very slight miss ?
    This is the senosr that sits above the coolant temp sensor .... I should just replace the thing I guess ... how much are they ? just unplug and unscrew by hand then put new on in and reconnect ?
    VP Exe
    Jan 2010
    yes check if it is fouled though and then clean it and out it back in.
    Its kind of hard to pinpoint a slight miss from a forum, it could be faulty leads or plugs too.
    Or for that matter any number of things, you will have to do some reading in the manual...
    Mainly there are two things that your basic trouble shooting should determine..Fuel Or electrical
    I think you will find that there are many of each, so the trick is to first find out if it is a fuel issue or spark issue.
    Dan
    VP Executive R-spec
    Jan 2005
    Jun 2006
    My mate who works on skylines for a living told me to replace my ngk sprak plugs again ..
    he said I should change them every 12 months no matter what.... he said they use them at the track and throw them away after a days use ...
    thanx for the reply greenfoam ... aslong as thats not cauing the miss then I will leave it alone.. new spark plugs again me finks ..
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Pull the plugs out and have a look at them. All race cars would be replacing plugs after each race. Im sure that you wouldn't be driving your car around in the same fashion that a race car does going around a track.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    VP Exe
    Jan 2010
    Quote Originally Posted by Matt_vp View Post
    Matt
    I agree, if your spark plugs are less than 12 months old, just clean then with some light sandpaper and some wire.
    I am sure I have cleaned pluggs older than 12 months many times with good results so go figure...
    Take note if they are very black and grimey (fouled)
    Dan
  1. RB30 Engine Troubleshooting/Maintenance Step by step
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-07-2010, 05:23 PM
  2. how di i change my lsd diff in vt calais v6 is it hard any one have a step by step
    By dazz9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 12:20 PM
  3. How to change a sump step by step instructions needed!!!
    By karron in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-10-2009, 10:19 PM
  4. Replies: 13
    Last Post: 12-06-2009, 09:10 PM
  5. Step By Step Guide for Replacing the Crank Angle Sensor (CAS) on an RB30
    By detox_nath83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-03-2009, 08:57 PM
