Results 1 to 13 of 13
Thread: Rust....
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Rust....
    Can this rust be fixed? Its only surface really but in a very bad spot.
    Also whats been added to the boot here? Ill put in comparisen shots, cause on my V6 its rusting in that spot but what ever has been added to the V8 looks like it's stoped it.
    V6
    V8
    And i might as well put this up, its got a rust whole around 3mm in diameter in the door sill and surface rust around that. I assume that can get reparied easily?
    Thanks.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Inside the roof rust would not be easy to get to. I've seen a few like it and I guess at some point it will take the life of the VN.
    The sil you just take the rubber off and attack it from there with rust kill.
    and 3 Dangerous non ABS VN's
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by 88GreenVN View Post
    I was affraid of that, im still undecided weather to keep the V6 or the V8 body...
    The Daily VN T5V6
    355 VN GRP A REP
    VP Executive R-spec
    Jan 2005
    I wouldnt worry about the roof, so long as you can stop the leaks getting into the car that cause it, it'll last 100 years like that. You must live reall close to the sea to have rust in the sill of a non white VN?
    cammed Vx ss m6
    Sep 2006
    it looks like your v6 has had the 1/4replaced and who ever replaced it never sealed the seems like on your v8 and the water has gotten in between the joins and rusted
    brockee's Avatar
    brockee is offline (HOUSE OF POWER)
    VX S2 SENATOR SIG CAMMD A4
    Aug 2009
    mandurah> wa
    i think its a vn thing with rust under hood lining like that ,as greenfoam said must a been close to the water salt etc ..... also with the rust on the roof my vn had it there , could be moisture geting in what are the door rubber like that could possibly be your problem ???
    88GreenVN's Avatar
    Jun 2006
    The rust in the roof comes from the back quater windows leaking into the car - which ends up in the boot. Not only will the boot lid on the inside rust but so will the roof.
    As Greenfoam said not all that serious - but one day it will be - and most VN's will be finished by then anyway
    VP Executive R-spec
    Jan 2005
    I think the seal in the boot must have been a running change with the VN's, that looks factory and I've definatly seem them without the seal. rust cant grow without water and if the car is sealed up good it'll last just as long as the vintage cars you use to see parked out in the desert for 80 years without any paint on them , spray some fisholine on the roof and forget about it. I've no doubt my VP looks the same as this as it's been leaking water from the rear 1/4s for a long time and was often full of moisture. But I'm not worrying about it
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    The car has been no where near the coast all its life Been in the family since new it was kept in a garage aswell.
    The Daily VN T5V6
    355 VN GRP A REP
    VP Executive R-spec
    Jan 2005
    Musta been down the production line on a day when the paint was running out then :P
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by mischa View Post
    Thats kinda scary seeing that much rusting hiding in the roof, especially in a non coastal car.
    VP Executive R-spec
    Jan 2005
    It's not really no Holdens or pretty much any car have ever been painted inside the roof or even deep inside the panels inside the car. There's plenty of cars 50 years old with surface rust on the inside of panels. So long as they don't see water it's no problem
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Oh well, ive decided to keep the V8 body, no rust but needs a respray. Just means ive got to now sell my beloved first car
    The Daily VN T5V6
    355 VN GRP A REP
  1. help with rust
    By gav555666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 11:53 PM
  2. Rust!!!!!!!!!!
    By Marzz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-04-2009, 10:05 PM
  3. Rust in car
    By Post Vintage in forum General Discussion
    Last Post: 13-03-2007, 11:27 AM
  4. Rust?
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 05:00 PM
  5. Rust
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2006, 11:00 PM
