Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: battery light with brand new battery
    vn executives
    Sep 2005
    Default battery light with brand new battery
    hi, guys, my 4 years old battery just died on me.the battery light comes first, it comes and goes for a while and out of the sudden, gone. got a new one, century, for 150 bucks. put it on, same things happens, the battery light comes out and after I drove for 20 km, it disapear. the next day, the same. I thought it was the battery, but after changed to another one, still the same. could it be the alternator?the guy from supercheap recon it is the ECU. thanks.
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    battery lights is the alternator warning light. it means the alternator is not charging.
    need to check with a voltmeter to confirm.
    VP SS
    Jan 2008
    Hiding in WA somewhere
    VP Executive R-spec
    Jan 2005
    You old battery is probably still ok, the regulator on the alternator might have just run out of brushes
    VY SS
    Jun 2006
    Albany
    vn executives
    Sep 2005
    Quote Originally Posted by greenfoam View Post
    how do I fix it, and how much. do not wanna invest more, might need to dump the car.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    just buy a sencond hand alternator if you dont wanna spend much,ebay or something like that
    VT SS 5.7
    Mar 2005
    Goulburn
    hey mate had same kind of thing happen to me, changed the battery and alternater and still had battery light poping up every so often, never did find the problem eaither
    Real cars don't power the front wheels, they lift them
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    the alternator could have also helped kill the old battery by running it too low.
    you car battery is not deep cycle, so they dont like getting too flat.
    Dan
    1992 VP vacationer
    Nov 2009
    just get a new reg for the alternator. About 25 bucks I paid. lol ECU, what a n00b. I never buy from supercheap, rip off dumb a$$es imo.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    vn executives
    Sep 2005
    Quote Originally Posted by Vlad01 View Post
    is that a regultor? where did you get yours. my bttery light went out today after I droveit for 20 km. if the alternator is gone, should it be on all the time thanks.
    VY SS
    Jun 2006
    Albany
    if you are still having probs get a test light and check for power on the main power cable at the alternator. then unplug the reg and test the 2 pins in the plug, one should have a constant power and the other one when probed should bring up the battery light on your dash. if you have got all these then there is something wrong with the alternator. cheapest option would be to try a new regulator which might fix it, if that doesnt work your other options would be either get a used alternator from a wrecker but thats prob not the best idea, or you can either get an exchange alternator from an auto electrician or get a brand new one.
    kym192's Avatar
    kym192 is offline kym j
    VH sl, VT berlina, VN berlina, VH SL\E
    Jun 2009
    south coast south aust
    i had the same problem with mine just get a different altinator and just swap it over, i had the same problem not that long ago 4 batterys 3 altinators later its working fine then all my other problems started lol, if ya going to dump the car at lest get insurance first and torch it lol
  15. #15
    vx s pack II
    Jan 2010
    aLKIDA
    Check the voltage at the battery when the battery light comes on. You should be getting between 13-14v
    If not then get you alternator changed its not always the REG when the alternator goes
    it could be the rectifier as well. So get i new one or reconditioned one.
  16. #16
    vn executives
    Sep 2005
    Quote Originally Posted by PRAVX II S View Post
    hi, guys, thanks. just want to ask how long can the battery last without a alternator. the century one last me for 10 day, it still starts before I returned it. also why some times the light went out. does that mean it charge sometime?
  17. #17
    vn executives
    Sep 2005
    any one? if just few hours, I need to dump the car before it stop in the traffic. thanks.
  18. #18
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    mate step one dont listen to anything supercheap got to say.. all they kno is what they read of the packet. second its ur alternator.. also chek the power cable leaving ur alternator going to ur battery.. sumtimes they can burn out, cuasing a voltage drop.
  19. #19
    VP Executive R-spec
    Jan 2005
    Just get a new regulator for the alternator 95% thats the problem, they wear out like anything and need replacing once in a while
  20. #20
    vn executives
    Sep 2005
    thanks, I will get one today.
  21. #21
    vn executives
    Sep 2005
    hi, greenfoam, where did you get yours, I went to autoone, quoted me 70 bucks.
  22. #22
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    The regulator for the alternator has carbon brushes in it that run on the alternator commutator ring, the carbon brushes wear down until the contact becomes sporadic and your charging becomes too
    dodgy = battery light on dash lights up. The regulator is usually held in with just 2 screws, It is possible to replace just the carbon brushes but that's not a job I'd try myself. My regulator cost $50, maybe try ebay or look on the for sale forums here. Your old battery is probably dead from excessive discharge, if you can't get the regulator sorted ASAP then put a battery charger on each night and try not to drive at night or you'll be buying another battery.
    Warranty Void
  23. #23
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Check the tan wire is in good condition that runs from the reg to the positive on the battery.
  24. #24
    vn executives
    Sep 2005
    Quote Originally Posted by Warranty Void View Post
    hi, got the regulator fro 71, how do you get it off, do you need to take the alternator off first? now I got a flat battery after drive the car for a week and 10 minutes at night.
  25. #25
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I swapped my regulator in the Repco car park where I bought the new one, 2 min job.
    Disconnect the battery and take the belt off the idler pulley. Undo the driver side alternator bolt and loosen the passenger side bolt a little (10mm and 13mm i think? Can never remember bolt sizes...). Disconnect the alternator and roll it upwards. Remove the regulator from the back of the alternator and install the new one. Two screws off memory. Lower the alternator back into position, reconnect it, tighten bolts, fit belt back on and reconnect battery. Problem solved.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. [VIC] Misc parts - gauge, steering wheel, speakers, battery cover, battery box
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 06-05-2009, 06:32 PM
  3. Which Brand of Battery?
    By Tom_1569 in forum General
    Last Post: 01-04-2009, 02:46 PM
  4. Battery Light
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 09:03 AM
  5. VP Battery Light
    By lostsoul1972 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2005, 09:24 PM
