Can I use that stuff on my vn if I have got dirty/blocked injectors and the normal injector cleaner stuff is not working well ??
I have seen youtube vids and it will blow alot of smoke etc ...
can this also be put in fuel or is it for spraying into inlet manifold only ??
can someone please explain procedure as I wish to give it a try ... I dont wont to have to pull them out and get them cleaned properly as I did this few years ago and cant be stuffed forking out more $$$
thanks...
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
hey mate ive used a few can fulls of this stuff its great, bascially all i did was take my plenum off and spray a good even amout down each runner, let it sit for 15min then started her up, it blew lots of smoke n crap, to this day havnt had any problems from doing it and it ran much better after doing it (ive done it like 4 - 5 times)
good luck
Edit: Dont put in fuel, also someone else will have to clear up about using it on injectors, not sure on that one
The best way ive found to fix dirty injectors is remove the fuel hose going into the fuel rail and remove the pressure regulator assy. Using an air line blow out any excess fuel in fuel rail. spray subaru upper engine cleaner into the fuel rail until it freely flows out the end of the fuel rail. Refit the pressure reg and fuel feed hose to the fuel rail and let it sit for an hour. Start engine. This method cleans the bucket filters in the injectors and injector pintel. Use the rest of the can to remove the carbon in the inlet manifold and heads via the method shown at the end of the previous link.
Cheers Steve Sti Subaru Melbourne.
Sti Subaru Melbourne "the home of Sti"
