How hard would it be to swap cruise control from a 1993 vp excetive to a 1992 vp excetive? shouldnt most of it already be in there?
I think you will find none of it including the wiring wont be there, pretty rare to have an exec with cruise control it would have to have been optioned at dealer or fitted later on.
Its possible to fit though, hardest part is pinning 2 wires that go to the instrument cluster plugs, and the switch block plug. Then you just have to install the second brake switch and run the loom that goes into the engine bay to the module, which just mounts with 3 bolts (probably require drilling into the guard), the cable is easy to install, just requires the throttle body bracket of donor car. I wouldn't suggest attempting it unless you know what your doing
Power is measured in DECIBEL
