Results 1 to 18 of 18
Thread: VN Front strut removal and install Q's
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Default VN Front strut removal and install Q's
    Im just wondering how you remove the front struts an replace them. I have done them on a VR before but not a VN is the much difference? Iv done a brief search but couldn find anything. Im taking out my factory suspension an putting in all new suspension that im ordering from GSL RallySport. Just after a basic guide.,
    Thanks
    Signature Goes Here
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    I think.. your VN car manual will tell you.. If not, a Gregorys one will
    Im sure if you look at it.. it should be straight forward to remove ?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    The ball joint is the hardest to get out, if you even decide to do it that way. Unlike the VR it dosent just unbolt.
    I just took the whole strut out control arm connected. Much easier, getting the old shock undone was a bit of a bugger aswell from memory... but it can be done! The shock is seperate from the strut in a VN.
    You proberly already know you need spring compressors right?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How To: Change Springs/Shock
    The search function really does work....wow.
    Visit my Facebook page
    vp_commo is offline Banned
    VP Exe
    Jan 2010
    Greenslopes,Brisbane at present
    Quote Originally Posted by mischa View Post
    yeah thats what I do, and drop it off at the brake place to get some new ball joints pressed in and the old pressed out..
    I have belted new ones in with a hammmer .. it does work but really doesn't feel very professional.
    Dan
    Nimbus 2000
    Sep 2008
    Hogwarts
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I found that thread but was more after pics an more specific info like torque settings but never mind il work it out.. Thanks for the replies
    Signature Goes Here
    VNAer0HDT's Avatar
    VNAer0HDT is offline Bricky - We lay You pay
    VN Berlina
    Aug 2009
    SA, Adelaide
    Nimbus 2000
    Sep 2008
    Hogwarts
    Quote Originally Posted by VNAer0HDT View Post
    will it improve much on a vn berlina??
    and will it fit?
    Im sorry but what do you mean.. is confused
    Signature Goes Here
    Nimbus 2000
    Sep 2008
    Hogwarts
    ok,, how the hell do you do the front struts a got some excel-g from gsl rallysport an cant figure it out but the shock looks different. any help would be wonderful
    Signature Goes Here
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by shane_90 View Post
    What part#? Once you have removed the strut, need to compress the springs to remove the strut tops, then remove springs which will reveal the shocks. I found a large stilson wrench the easiest tool to crack the large nut holding the shock in.
    Power is measured in DECIBEL
    Nimbus 2000
    Sep 2008
    Hogwarts
    ok,, the bit that got me confused is that my strut that i ordered appears to be different somehow an me an mate have been trying to sus out how the hell the strut stays in there,, obviously the bolt on top keeps the top on an the spring but the bottom that's were we lost an have no idea, how does it all stay in.. probably not making much sense.
    the pic is of the strut i got from gsl, its like a replacement cartridge
    Attached Thumbnails Attached Thumbnails VN Front strut removal and install Q's-03032010132.jpg
    Signature Goes Here
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    It should have came with a large gland nut for each shock?
    once you remove everything you will see it, but you need a HUGE shifter or large stilson wrench to remove it, and it basically holds the shock inside the strut. Heres a pic
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Nimbus 2000
    Sep 2008
    Hogwarts
    thats exactly wat i was wanting to know thanks heaps for helping to clarify that.
    Signature Goes Here
  15. #15
    VZ AWD One Tonner
    Jul 2006
    Also DON'T fill the strut body with any oil. Some shocks asks for it, the KYB DON'T!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  16. #16
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    1 Tip which will save epic annoyance.
    Put lock-tight (loktite? lock Tite? sp?) anyway, on the castella nut to avoid it coming undone later. What happens is it wriggles loose (even with epic tightening) and then the shock jumps up and down evtually cracking and the fluid leaking out, aka killing the insert.
    Had it happen to me and several others have also reccomended this procudre!
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  17. #17
    vn exec
    Dec 2009
    no need for spring compressors! pull the bottom end of the strut out first then jack the bloody thing up. using car stands under the chassis rails undo the top end. i changed all the suspension from a vn calais that i wrecked into my exec it was pedders super lows all round with the springs cut in the back. exec was standard calais was dumped, the exec ended up looking tuff with the calais suspension in it. you can buy ball joint removers and tie rod end removers for next to nothing i picked up both in a fork style that you smack with a hammer for about 13 bucks each from autobarn when they was on special rrp was like 24 bucks each. also got a different style it uses a bolt to push them out for about 35 bucks. worth a look at. spring compressors can break if you buy "cheaper" ones from say super crap and have been used a few times.
  18. #18
    Nimbus 2000
    Sep 2008
    Hogwarts
    Thanks for the tips,, gonna have a go on Sunday arv. will let you know how i go.,, im sick of low rear an high front its annoying the hell outta me,,
    Signature Goes Here
  1. [VR-VS] VS strut removal
    By jashdown91 in forum Holden Commodore How-To's
    Last Post: 11-05-2012, 08:25 PM
  2. front strut removal
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2009, 10:47 AM
  3. vs strut removal
    By -(TR1PZ)- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 12:59 PM
  4. Strut Top removal with no Rattle Gun
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-10-2006, 08:39 PM
  5. Front Strut Removal
    By Spinksy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2004, 08:01 AM
