g'day yesterday i ripped the diff out of my vp ss getting air over what i thought was a smooth rise..... i found out it was held in by the two front mounting bolts and the rear bushing only. i snapped one bolt and tore off the passenger side mount. i cant weld this as the casing is cast iron. so i had to re tapp the thread in the rear mounting brakets. just wanted to know if its ok to drive with only 3 of the 4 mounts attached and the rear bushing still attached.....
cheers
jono
Which bit is cast iron?
I thought the brackets on the diff where steel and the tube is steel.
Matt
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
VP ss is IRS yeah?
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
yeh, well mine is.... and yeh the diff casing is made of cast iron...
btw dont buy anything from "burleigh auto wreckers" they couldnt even tell the difference between a single spinner and an lsd...
I would say there's a very big chance your irs cradle will crack without all 4 bolts in and done up REALLY tight
ok i took it up behind pac pines nd gave it a good thrash... somewhere in the vecinity of bout $2.10... feels pretty solid but im still a bit worried bout it on rough roads... its not just the cradle holding it, it has 3 of the 4 cast casing mounts holding it too....... i cant belive i ripped it out, such a pain in the ass! i dont wanna get another lsd either cause it has a clubsport one in it..... nd i wont find another like that one for under $500![]()
ok bit the bullet and bought a vt lsd... upsized bolts to 14mm high tensile, retapped threads..... i could literally hang the vp from the diff now lol, badass bolts.
