Results 1 to 12 of 12
Thread: Fuel Injector..not working
    vn 91
    Dec 2005
    Unhappy Fuel Injector..not working
    Just got a new fuel pump installed and now cant hear the Injector Starting up and when i Start up the car it splutters and coughs badly...Never did that before with the old pump still there...Dont know much about these things..Any Ideas.....Thanks
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    VT SS 5.7
    Mar 2005
    Goulburn
    check your fuel filter(Down near the tank) when you changed the fuerl pump sum crap might have been sucked up the line, or check the fuel pressusre regulator(on the end of the fuel rail)
    Real cars don't power the front wheels, they lift them
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    what do you mean by cant hear injectors starting up?
    all you should hear on the old vn/p is a clicking, and when the car is running, this you should feel when putting hand on the top of injector
    bit more info need.
    i am the god of britany spears womanizer on just dance on the wii
    vn 91
    Dec 2005
    I didnt put the fuel pump in ..my mechanic did and i got no clue where the injector is and yes i hear a click when i start
    Feb 2010
    you may need to take it back to the mechanic if your not confident in trying to repair it yourself.
  7. Default
    Quote Originally Posted by Gerrys888 View Post
    i think you need to read about how a fuel injected engine works. there's plenty of info if you search google. do you know what an injector is, what it does, where it might be, and how many your car has? (you keep referring to it as a singular)
    the reason i ask is because i want to know what you're expecting to hear from your injectors if you don't know anything about them
    the injectors don't make a sound when starting up. they click every time they open when the engine is running. if you lift the bonnet you can hear clickclickclickclickclickclick, that's most likely the injectors because vns are notorious for having noisy injectors.
    i'm wondering if you mean you can't hear the fuel pump prime? that makes a buzzing sound from the fuel tank when you turn the ignition on. maybe the new pump is quieter than the old busted one. for the spluttering you can check fuel filter (as suggested), cas, leads, plugs... grab yourself a gregories workshop manual as well, save you some mechanics bills
    Quote Originally Posted by zai View Post
    I am not sutpid
    vn 91
    Dec 2005
    Question
    Quote Originally Posted by levymetal View Post
    Thats it...the buzzing sound is gone...must be the new pump..But it still splutters when i startup...Its not getting fuel i think
  9. Default
    does it run ok after it splutters to start up? maybe they put a new filter in the wrong way, i think i read somewhere that it can make a difference.
    I am not sutpid
    vn 91
    Dec 2005
    Yeah it runs fine...but once or twice it stalled on me when i was driving...Apart from that its OK
    VT SS 5.7
    Mar 2005
    Goulburn
    Coil pack might be on its way out, maybe spark plug/leads
    vn 91
    Dec 2005
    Well its due for a service...So maybe that will fix it
  1. Fuel injector upgrade
    By HSV.421 in forum V8 Development and Modification
    Last Post: 20-12-2009, 08:36 PM
  2. Fuel Injector Help
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2009, 12:34 PM
  3. [VIC] wtb vp v8 fuel injector
    By HSV472 in forum Swap / Wanted to Buy / Trade
    Last Post: 12-12-2008, 12:21 PM
  4. Injector not working ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-10-2008, 08:06 PM
  5. fuel injector service
    By boourns in forum General
    Last Post: 09-04-2007, 05:06 PM
