Results 1 to 4 of 4
Thread: Problem with aircon controls 89 VN
    1989 VN Commodore
    Feb 2010
    Default Problem with aircon controls 89 VN
    My 89 VN commodore sedan's aircon is stuck on the feet part for the controls and i can't seem to get it out to screw the hose back on so it will change. I've taken the dials off and im stuck with a white casing that won't come off. Anyone know how i can take it off? Pictures would be great but i can read if needed :P Cheers.
    Calum.
    1989 VN Commodore
    Feb 2010
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Have you got the unit out of the car?
    If not I doubt that the problem lies within.
    Have you checked all the connections on the rear of the unit?
    Maybe the vacuum hoses (whatever the hose-block on the rear of the unit is called) have
    merely come unplugged?
    I would check a few of these things before i pulled the unit to bits, as I don't think that will end well
    (Im not sure they're supposed to be separated).
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I think he means he cant get the actual control unit out of the console.
    If thats the case mate you need to take the center console out so you can take the facia off that surrounds the heater controls and the radio. Once the facia is off its one screw to get the heater controls out. Behind the controls are two electrical plugs, the vacuum hose attachment and the rod to the little white lever on the side of the heater unit. Its a pretty easy job to do just take it easy and dont force anything as it's not hard to snap/crack parts of the console.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  1. how do i fix the aircon/vent controls
    By Jezza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2009, 09:41 PM
  2. VY heater , aircon controls
    By putz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2009, 11:33 AM
  3. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
  4. aircon controls question [84 vk berlina]
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2006, 11:05 PM
  5. VP aircon controls
    By Pico in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2005, 02:20 PM
Tags for this Thread
