Results 1 to 7 of 7
Thread: T5 hard shifting gears
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default T5 hard shifting gears
    Hey guys my vn hasn't been driven in over two years. I've just fixed it all up again and regiatered it. And I'm now driving it round. It's being a pain in the ass. And really hard to shift into gears. The only things I can think of are that the shifter mechanism needs grease or the gearbox needs more fluid. Any ideas??
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Maybe it was always like that, and you were just used to it? lol
    new oil?
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    i have the same problem. im thinking that its the shifter mechanism. its very notchy into gears and sometimes when im stopped at the lights and go to select first gear it is very difficult. im going to check the oil tomorrow. i know that my clutch is hammered and needs to be changed very soon but i doubt that may be the problem, but who knows, it may well be.
    George
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    A buggered clutch will make it harder to shift. A clutch cable that isn't adjusted properly will give similar problems.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    well ive partially fixed mine. dropped the oil from the gearbox it was about as black as used engine oil.
    replaced it with some fully synthetic and its feeling alot better. still need to make sure the clutch is adjusted properly but so far so good
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    if the clutch isnt adjust then itl will just keep trying to turn the gears in the box, and you pushing into gear the synchros slow internals down until they match speeds and itl clunk into gear, where does your pedal grab and start to move the car? if its almost as soon as it leaves the floor then the cables to loose
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    how should the clutch cable be adjusted and to where? im pretty sure that my clutch is gone. i have an exedy heavy duty and it was heavy when i first put it in but now it is heaps softer compared to what it used to be. even my mate said the exact same thing about it.
    George
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. HARD shifting when engaging gears from park
    By vsl67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2009, 07:55 PM
  3. Like shifting gears? Have a look here...
    By VT-565 in forum Parts And Other Items For Sale
    Last Post: 26-02-2009, 09:09 PM
  4. VP Hard Shifting/Kick
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2008, 11:36 AM
  5. revs to high and gears not shifting right
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2005, 04:35 PM
