Results 1 to 14 of 14
Thread: Thermostat
    VP Commodore
    Feb 2010
    Exclamation Thermostat
    hey guys,
    where is the thermostat located and how do i change it??
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Is your engine series 1 or 2?.
    If it's a series 1 engine, the thermostat hides at the back of the engine. (Look for a hose leading to a pipe with a "Screw on it (Called Bleed-Valve)"
    If its a series 2 engine, it will sit right on top of the engine.. Look at your Right hand side hose (Driver Side) and follow it to a pipe on the engine with a Bleed valve.
    [EDIT - This is NOT my engine.. It's a random one off the Internet]
    This is where the Thermostat is located on the Series 2 engine
    Remove the bolt, and the thermostat hides inside
    ** But before doing this, make sure you drain the the coolant first!
    Undo the bottom hose of the radiator..and let it drain.. when its empty remove the top hose leading to the Thermostat.. Undo the clamp.
    Once the hose is off, undo the bolt..And your set
    You can get a new Thermostat at Super cheap cheap for $10-30 I think?
    BUT! Do this on a cold engine tho! Dont want you get to burnt!!
    Good luck!
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VP Commodore
    Feb 2010
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    No probs
    Good luck!
    For people wondering whats the deal with this engine.. I have no idea LOL!
    VP Commodore
    Feb 2010
    by the way, once i put the coolant back in the engine, wheres the bleeder valve to get rid of the air in the system?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    In the black circle, thats the bleed Valve. You will need a Flat blade screw to release it, DONT fully undo it tho
    *When you do this, make sure the engine is cold
    VP Commodore
    Feb 2010
    but once i chuck some coolant back inside, dont i need to turn the engine on and bleed the system of air while putting more coolant in?
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Shoulda put that in lol..sorry.
    Put the coolant in first..
    Undo the Bleed Valve (not all the way)
    Turn your A/C on..and put it on the HOT temp side
    Start the car up..And add more coolant untill it's full wile running.. Then fill your Overfill bottle to .. And wait roughly 5min .. then close the Bleed valve.. and ya set!
    Then put your A/C back on cold or off..what ever you wana do with it lol
    VP Commodore
    Feb 2010
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Good luck.. Need anymore help.. feel free to reply back here..And I or some one else will respond
    VP Commodore
    Feb 2010
    nice ride u got btw. i love the VP in particular for some reason. mine had a ugly looking spoiler on it, got rid of that. under it was the orginal shine of the paint ( i assume that the spolier was on there since it was built). nice dark metallic blue paint. but the rest of the car has lost its shine. just a dull mettalic blue. a good buff should bring the colour back out.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Thanks
    Haha, same with mine when it was removed
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    With the permission of Shane_90 I got a pic of his engine.. A Normal one lol
    See his Ride here.. My soon to be new vn
    Inside the Red Circle is the Thermostat Housing
    Inside the Yellow Circle, is the Bleed Valve.
    Dec 2009
    Quote Originally Posted by Dumster View Post
    Good luck!
    There's no actual designation series 1 or 2 however most refer to the older engine with the thermosat at the back as series 1.
    The older engine lets callit series 1 does not have any bleed screw in it's cooling system it uses a surge tank that sits above the engine and radiator and the pressure cap is on this tank, you simply fil it up with the heater tap on and it is self bleeding. The revised design lets cal it series 2 has a bleed screw similar to the ecotech because the top of the engine is higher than the radiator and traps air so you have to bleed it out. You only need to fill the system with the heater on through the radiator while it is cold using a hose, gatorade bottle with the bum cut off and thread taped with electrical tape for a seal or whatever shoved in the radiator where the cap goes to give a head higher than the top of the motor and have the bleed screw undon a bit and keep filling until coolant comes out of the bleed screw with no air.
    If the coolant is good drain it into a clean bucket and reuse it. If you top it up use pre mixed and it has to be 50% concentration for these engines, 33% in no good the coolant will boil around the valve area in the heads.
  1. To be or not to be? (Thermostat)
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2009, 11:55 AM
  2. Thermostat .....i think??
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2009, 10:05 PM
  3. Thermostat
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2009, 05:26 PM
  4. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  5. is it my thermostat
    By 5.0L UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2008, 04:05 PM
