Results 1 to 16 of 16
Thread: Beeps when starting
    Holden vt calais 5 litre
    Nov 2007
    Default Beeps when starting
    Sometimes when starting my dash will beep once or twice at me I have no idea why. I have checked for errors and got code 12 and I never run the fuel tank down any thoughts ppl?
    Nov 2007
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    What sort of beep is it?
    Continuous?
    1 beep every few seconds.. etc?
    Beeping Codes from Level 3 Clusters
    Overspeed A = T4 pause (1) T3
    Low fuel B = T2 pause (1) T3 pause (4) repeated 5 times
    Hot engine C = T1 pause (1) T2 pause (1) T3 pause (1) T3 pause (1) T3 pause (1) T3 pause (1)
    Park brake C = T1 pause (1) T2 pause (1) T3 no pause T3 pause (1) T3 pause (1) T3 pause (1)
    Press remote B = T2 pause (1) T3 pause (4) repeated 5 times
    T1 = 2560 Hz 1/8 sec
    T2 = 3200 Hz 1/8 sec
    T3 = 4266 Hz 1/8 sec
    T4 = 6400 Hz 1/8 sec
    Pause = 1/8 sec
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    So, Code 12 is "Code 12 - System Pass (OK) "
    88GreenVN had an beeping issue with his Park Break.. But, I believe.. It was not a beeping issue... Just the Light on his Dash
    Check here for his thread Handbrake Warning Lamp Fail
    EDIT - Does the beeping still occur wile the car is turned on..and while you are driving?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Yep had 2 things - 1 was the park brake switch was stuck and the 2nd was the voltage regulator had a cracked solder joint on pin No 1.
    and 3 Dangerous non ABS VN's
    Nov 2007
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by justice4all3000 View Post
    It beeps once only when I crank the engine
    That is an odd one indeed....
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Could be a bad signal from the CAS to ECU then to Cluster maybe?
    I do believe, there is a fault about to occur tho..
    Maybe, you could try replace your leads and plugs..And maybe the coil pack.
    When you driving, does the engine light ever come on?
    Do you start the car with the Hand Brake on? - If not, you may have a similar issue to GreenVn's maybe.
    I don't think lvl 3 clusters beep when starting up do they - As mine doesn't.
    How about yours GreenVN, does it beep at all when starting up? (turning on accessories..then engine etc)
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Dumster View Post
    Nope - never get a single beep on start up.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    To clarify, just a tad more.. This Beep only happens ONCE when the engine is JUST about to Crank.. Or mid-way thru it?
    Nov 2007
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    silly Q.. but do you let the Fuel Pump prime before starting up?
    Nov 2007
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    once the engine is just about to crank.
    it sparks up.. then begins to crank.
    Your issue could very well be a slight dogey spark.. Check your leads and plugs mate
    OR.. Start you car, let it idle for say 5min..
    Put you hand on top of the Coilpacks.. If any are more noticeably hot than the rest.. you've got a dogey one.
    On a Cold engine.. pull one of your Spark Plugs out, and see if they need replacing.
    Im almost positive, you have a minor weak spark, hence the beep..but then it sparks up good enough.. So the cluster wont beep anymore
  15. #15
    Nov 2007
    I have tested the leads and coilpack with a multimeter, couldnt find anything wrong with it, the plugs were replaced not long ago and I also have sanded the crud off the metal plate on the dfi module however I do have an idleing problem when the motor is warmed up!
  16. #16
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    for the rough idle, you'l need to clean the TB out
    As for this beep, it could be a wiring that is lose or dogey.. take ya cluster out.. and check the wires behind the cluster..
    There are White Plugs in your dash.. pull it towards and check all the wires are seated in there nicely
  1. VS Warning Beeps
    By DocBald in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2009, 11:41 PM
  2. Airbag beeps
    By simso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-11-2006, 02:38 PM
  3. Beeps when i slow down
    By iplzher in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 12:43 AM
  4. Anyone know what the 9 beeps mean on startup?
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 09:51 PM
  5. It Beeps At Me?
    By Robbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2004, 12:06 PM
