Results 1 to 6 of 6
Thread: where to buy thermostat?
    VN EXEC
    Feb 2010
    Default where to buy coolant temp sensor for a 91 VN?
    hi, im going to change my radiator and im thinking it is a good idea to change the thermostat and cooland temp sesnor, so i can cover all bases... wheres best place to buy the new sensor and t'stat and are they easy to install?
    VS Berlina 3.8
    Dec 2008
    Yes, it is probably a good idea to replace the thermostat at the same time. However, when you don't mention anything about where you live, it's hard to tell you where to go to get it, and on that note, maybe you should take the initiative to ring around for prices from a few places local to you for something as common, cheap, and readily available as a thermostat.
    VN EXEC
    Feb 2010
    sorry i thought a chain of auto shops might sell them.....but i live in melbourne east suburbs,
    im also thinking of changing coolant temp sensor as well as thermostat and radiator, good idea?
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by joeyd View Post
    Yes, every chain shop will stock them (thermostats), they are one of the most common parts, and because of that, there's really no "best place" to get them. Don't bother with the coolant temp sensor if you are not having problems with it.
    EDIT:
    Sorry, I misread your question. I thought you were only asking about thermostats. You might have to hunt around for the sensor.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Search the "How To" section.
    I believe someone has covered changing the thermostat.
    Sep 2004
    I've even seen them at service stations especially for commodores
LinkBacks (?)
  1. Thermostat
    By emil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2010, 06:15 AM
  2. Thermostat .....i think??
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2009, 10:05 PM
  3. VX V6 Thermostat
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 05:54 PM
  4. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  5. thermostat and new fan
    By yobbo88 in forum Electrical Wiring / Questions
    Last Post: 14-08-2006, 06:16 PM
