the symptoms are; overheating on hot days- temp gauge gradually climbing to maximum and not dropping untill i stop the car and let it cool down.
I loosened the bleeder to try and let any air that might be in the rad out and since it seems to have been better, but what could be the root cause? bad thermostat/ engine coolant sensor/ fan sensor/ radiator crack?
Is the fan coming on? When was the thermostat last replaced?
if ur loosing coolant, you may have a leak but chek the overflow bottle when u stop the car. if its overflowing you will most likley have too much pressure in the cooling system, which could mean bhg. also chek ur radiator isnt blocked, look for cool/hot spots on the radiator by using a temp tester or ur finger lol....
Are you topping up with water because if u are this
may be the cause of ur
problem as the water will just evaporate...
I had a similar problem not so long ago I flushed the rad, put new coolant and
bled the system this didn't fix the prblem so I removed the thermostat
and repeated the above
steps and all was well that's pretty
lazy though do all of the above but replace the thermostat
thanks guys i think i might replace everything like you have suggested, one little thing, i dont know what dumster means by ' flush the block', please explain,
thankyou!!!
By the block, I mean the whole cooling system..
Rad , water pump & Thermostat housing..
however, it is always a good idea.. to get it professionally flushed.. So they can get ALL the crap and dirty shit outa the Block![]()
