Results 1 to 15 of 15
Thread: Temperature when idle
    VP Commodore
    Feb 2010
    Exclamation Temperature when idle
    hey guys,
    when my car is idle the temp goes upto half way. just was wondering if there is a coolant temp sensor that might need to be changed to turn the engine fan on earlier??
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    ECM controls the fan via the ect which should turn on at 104 degrees and off at 96 degrees , when was the last time you flushed your cooling system and what mix of coolant you using ??
    VP Commodore
    Feb 2010
    ive used a bit of water cos the coolant was low. i will change the coolant soon. but just in case, is their a coolant temp sensor that can be changed??
    strgas's Avatar
    Oct 2009
    there are too sensors one is for the gauge and the other is for the ECM. could be the gauge reading out of range too
    VP Commodore
    Feb 2010
    strgas's Avatar
    Oct 2009
    there could be some extra resistance in the temp sender wire cause the gauge to read incorrectly high resistance on the dash earth wire or some nut from strahfeild has installed the stereo incorrectly causing a voltage spike or overloaded a circuit
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    VR Commodore V6
    Sep 2008
    Sydney NSW
    As ^^ said.
    That's perfectly normal for a standard setup to go to.
    Mine comes on slighty above the normal operating temperature, but that's thanks to an adjustment I got made by Greenfoam when he did my tune.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    1992 VP vacationer
    Nov 2009
    yeah mine goes half way when idle and only first notch when driving. So I guess thats normal.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Yup..
    Though personally, I didnt want the fans cutting in at 104c, so now they're set to cut in at something like 95c.
    VP Exec SW
    Jun 2005
    Quote Originally Posted by crazybiker View Post
    Yup..
    Where is the sensor and how did you change the cut in temp?
    1992 VP vacationer
    Nov 2009
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    the other thing you can do if you're worried is wire up a switch a wire spliced into the earth for the thermo fan relay which normally just goes to the computer. this way you can switch the fan on whenever you like... theres a thread about this in the how to section i'll try and find it...
    Subaru Liberty
    Feb 2007
    'Tis normal. Mine does that. Typically it will run tad under the second notch (first major one). It will reach up to halfway, fan comes on, and it goes down. All normal.
    <<<< The information went data way! >>>>
  15. #15
    VR Commodore V6
    Sep 2008
    Sydney NSW
    As I said, that's the proper operating range for a standard tuned car.
  1. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  2. VS fix for temperature gauge showing between 1/2 & 3/4 on idle
    By VS_Commodore_101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 07:14 AM
  3. High Temperature at idle
    By HsvMan in forum General
    Last Post: 12-07-2009, 11:11 PM
  4. VS Idle Temperature
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-05-2009, 09:04 PM
  5. VS Temperature
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2009, 02:51 PM
