Results 1 to 14 of 14
Thread: need help gearbox (auto)
    vn ss 355, vl, vr, vs ss
    Jan 2010
    Default need help gearbox (auto)
    as above
    will a vp s2 gearbox (auto) fit a vr s2?
    VS Berlina 3.8
    Dec 2008
    It will bolt up fine, but the VR had an electronically controlled box, whereas the VP didn't. To the VR ECU, it will appear as if there is no gearbox there.
    Jan 2010
    VS Berlina 3.8
    Dec 2008
    You might be able to get it to work properly with a new memcal tune. I don't know if you could swap all of the loom and electronics from a VP or not. Other than that, not much.
    Jan 2010
    vn commodore
    Mar 2010
    gladstone
    use the vp memcal in the vr , have done this myself only recently with my brothers vr commodore. the vp runs hydralic servos and the vr runs electronic. the motors run the same tune but the vr is tuned to run the electronic box.
    Jan 2010
    Jan 2010
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no its doable but difficult youll loose torque convertor lockup and speedo without pulling both boxes to bits.you can run a vn ecu and wiring loom for the engine and then run the vn box but its just as easy to find a vr auto
    Jan 2010
    im only askin beacuse i got a vp here that run's.. but i need the vr runnin so i can get all parts from the vp
    Jan 2010
    VS Berlina 3.8
    Dec 2008
    Delcowizzid's answer will most likely be the definitive answer, it would be much easier just getting a VR auto.
    Jan 2010
    yes i no that but when u r in a town where there is only 300 people its abit hard.
    Jan 2010
  1. Auto VX V8 Gearbox Swap (with another auto)
    By Tom4321x in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-02-2010, 09:21 PM
  2. VS V6 Auto gearbox
    By paulbenning in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2009, 01:05 PM
  3. Auto gearbox
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2009, 02:08 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. auto gearbox
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2005, 12:13 PM
