Results 1 to 7 of 7
Thread: Help on error code for VN
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Exclamation Help on error code for VN
    ok i have been looking around on here an other sites looking for the issue, My vn keeps flashing up the check engine light,, iv checked for codes an 23 comes up., now from what i have found it means:
    " MAT sensor shows < -30 degrees C for 3 seconds after engine
    running 1 minute or coolant > 30C. Probably an open circuit."
    My question is what does this mean an how do i fix it,, really confused as to what it could mean,, i have a feeling its something simple an iv just over looked it. any help would be appreciated.
    Thanks in advance
    Signature Goes Here
    vn exec
    Dec 2009
    i honestly have no idea but would it be worth just simply replacing the sensor? i had problems with my car not long ago and it was the oxy sensor, i changed it problem solved. 5 minutes and $60 later. mat sensor may be different i dunno.
    Nimbus 2000
    Sep 2008
    Hogwarts
    im not even 100% sure were the mat sensor is,, thats the issue or otherwise i would of jus replaced an hoped for the best
    Signature Goes Here
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    in the back of the inlet manifold in the rear drivers side intake runner to the rear cylinder has a 2 wire plug going to it if you pull it out and water comes out thats the wrong one its the coolant one pull the other one
    Nimbus 2000
    Sep 2008
    Hogwarts
    Nimbus 2000
    Sep 2008
    Hogwarts
    would i be correct in assuming the mat sensor could be the issue?
    because iv just replaced coolant an gave it a good flush, it wasn cooling like it should getting to high
    Signature Goes Here
    Nimbus 2000
    Sep 2008
    Hogwarts
    issue is all sorted thanks the good ol gregory's manual, finally brought one
    Signature Goes Here
  1. Error Code 42, help me please...
    By Changa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2009, 01:07 PM
  2. Error Code 85
    By misha in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2009, 09:32 AM
  3. VR v6 Error Code 45?
    By QIK51X in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2006, 11:02 PM
  4. error code 42
    By impakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2005, 02:34 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
