Results 1 to 8 of 8
Thread: better infectors?
    1992 VP vacationer
    Nov 2009
    Default better injectors?
    Say if you were to get new injectors for a VN, VP, VR, would it be better to get say VS, VT/VX injectors? I am wondering this not because they flow faster and I know its pointless unless you have done serious work to the engine and other systems, but would it improve fuel spay/atomization pattern? thus improving economy and give little bit better power?
    I assume you would have to get a eprom tune to suit.
    Would it be a good idea if you were to:
    70mm tb
    mace style cai
    mild head porting
    pacemakers
    catback rear exhaust
    200cpsi cat
    and a tune of course.
    curious to know if better injectors would help. I think "why not" considering reco vt injectors are the same price as vn ones.
    Cheers.
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    I tried this in my VR, VX injectors gave a noticeable increase in power, quite a bit actually. As for fuel economy, mine is currently chewing through petrol like you wouldn't believe, this may or may not be caused by the bigger injectors, Ive taken them out at the moment and put the stock ones back in, will see how fuel economy goes.
    Could be a lot of other things as well though.
    VP Executive R-spec
    Jan 2005
    Don't do it!. Those have the same total flow rating as a VN/P injector but they flow hugely different amounts of fuel when using the same settings as the VN/P injector. They are a very big problem infact, they will run about 2 points lower airfuel mixture ie. 12:1 will become 10:1 but it will be different in different places on the fuel map so it's just a disaster
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    thanks for clarifying greenfoam wheres the best place to get a good set of reco VN - VR injectors?
    VP Executive R-spec
    Jan 2005
    The tip lol. Wreckers etc then send them to a someone with an injector cleaner, try and get the same part number that belongs in the car
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    I did say reco didn't I? what's the different between "reco" and "sonic cleaned" injectors?
    how do I find out what the part number is for my car?
    1992 VP vacationer
    Nov 2009
    1992 VP vacationer
    Nov 2009
    hey again. I pulled out a set of injectors out of a VN donor. I noticed that they were a different colour.
    They are a gray with a tinge of blue/green. The PN is 0 280 150 917. The only info I could find on that num is that they are 210cc. They also have 4 orifices. Are these any good to use in my VP? I don't think they are the standards VN/VP came with.
