Hi there, im in the middle of changing my radiator and thermostat and im doing a radiator flush to clean the pipes. ive realised the coolant container is filthy but its attached to the windscreen cleaner container and thats got electronic attacments. i think i really need to clean all the dirt out of the coolant container as im about to put in a new radiator.....also there is coolant still in there that didnt come out with when i pulled off the bottom hose.........any ideas...
thanks
the electronics is just the plug to the motor for your water jet things to spray your window on your bonnet.
just unplug that and take your bottle out, put some water in it and shake it around
93 VP Ute, V6 5 Speed
You will find it easier to clean by using a solution of water and CLR (available from most supermarkets or hardware shops) leaving it stand for half hour or so. Repeat if necessary. A cheaper and as effective way is about a cup of water, handful of small pieces of gravel and shake it all around until the inside looks clean. You can finish it off with some wet sand inside. Make sure you rinse it well before re-installing. A small bottle brush used with the set sand will help to remove stubborn stains particularly in the crevices and corners.
baking soda and vinegar should do the job, some guy at the wreckers told me that but i didnt end up bothering, just put it on
lol I do the gravel and sand thing too.
wouldnt put sand and gravel in the coolant container........eather you got the mans leg or being a clown...lol
Floor it and swerve driving skool
WTF are you talking about? You do remove the container from the car....
Not hard to flush it till there was no rocks once it's off the car.
You can actually buy these brand new (repro)
Theyre a good fit and look much better!!
Think i paid $70 for mine ...
