Results 1 to 8 of 8
Thread: how to make your accelerator cable tight
    vnwpn2 is offline Banned
    vn
    Feb 2010
    Default how to make your accelerator cable tight
    wher are the sxrews botls ect i have to tighten thanks
    vn
    Feb 2010
    vn
    Feb 2010
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If you put your right foot on the accelerator pedal, push it all the way to the floor and hold it there, the cable should then be tight.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Quote Originally Posted by Benboy View Post
    lmao and ur **hole will also be tight when it skates out sideways
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by vnwpn2 View Post
    Is there something wrong with you? You have specifically been told not to to this.
    Suspension shocks
    Quote Originally Posted by hakhawk
    frequent bumping of threads is NOT needed. someone will reply(though not to this thread) in time. wait at least 24 hours before bumping threads if no one has replied.
    should you feel the need to continue bumping threads so quickly, infractions will be handed out, or you will be put on moderated posts.
    VS Berlina 3.8
    Dec 2008
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by _R_J_K_ View Post
    Also what do you mean "tight"?
    He wants to make it so there is less slack and more tension in the cable. Do this with caution it doesn't need to be super tight or you may end up snapping the cable. Where the throttle cable goes into the throttle body there is a bracket which is bottled to the elbow. If you notice there is 2 nuts one on either side of that bracket. Tighten that and it will make it tighter. Probably best to have the car on so you don't do it too tight and have it rev out on start up.
  1. T/B only opens 80% when kickdown cable is tight
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2008, 03:31 AM
  2. Accelerator Tight
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2006, 01:39 PM
  3. Accelerator cable tight
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2006, 10:38 PM
  4. Help with accelerator Cable
    By tristanwalz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2006, 01:06 PM
