Results 1 to 5 of 5
Thread: vn or vr engine?
    samvn87 is offline homejobvn
    vn commodore series 1.vs series 2 esteem
    Feb 2010
    sunshine coast
    Default vn or vr engine?
    i just bought a vn commodore and i noticed it has a vr coil pack on it is there anyway i could tell if it is a vr engine ? coz apparently the engine number on the plates dnt match the engine number on the block was told this thru revs
    cheers
    NO CAR ATM.. -.-
    Jul 2006
    Feb 2010
    sunshine coast
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    What year is your vn? if it is a series one, there will be differnces, if it is a series two the engine will be the same. Some differnces are: the thermostat housing on the v6 is at the back of the engine on the passenger side under the intake plenum in the S1 as apose to at the front on the s2, The injector rails are different they are flat instead of round, S1 have no radiator cap, the trip computer screens on the L3 cluster had thinner numbers on the S1 than the S2 (also a differnt cluser layout and are incompatible, components bar the trip computer are though), S2 had a bit of black plastic in between the plenum and the intake manifold called a Bellmouth (was introduced to counteract complaints of rough idle and 'excessive' wheel spin), the heads are also different and so are the exhaust manifolds I think. Thats about all I can think of at the moment but im pretty sure theres a few more.
    Feb 2010
    sunshine coast
    well i knw it has a seies 1 radiator but i am sure the fuel rails are round not flat ah wheel its a v6 all the same
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  3. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  4. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
