Results 1 to 13 of 13
Thread: Taco help
    Holden VP wagon - http://forums.justcommodores.com
    Sep 2009
    Default Taco help
    my revs are flickering up n down for some reason now, the actual car revs are normal just the pin on the taco is jumping around and idea's what the problem is?
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Tuff-VP-Wagzz View Post
    Taco connection issue.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Take the cluster out.. Give it a clean.. On the connectors C1 to C3
    Then put it back in.
    If it still continues to do it..
    You will need to undo the whole Cluster.. Very easy to do, Undo all the screws and bolts on the back of the Cluster ..
    Once done, remove the Front Plastic cover.. To do this, there will be 3 more screws on the Bottom of the cluster (Where you Lamps would light up EG- Engine Light. Park Light etc)
    Once off, then simply unclip the Plastic Cover.. Once off, You will notice 2 black plastic Strips.. Pull them Upwards..Once there out, you will be able to take the Gauges out.
    Ok, so when you've done this, have a squizz on the Tach (chipset) for any loose and possibly burnt out wires. - If you can't find anything wrong.. Then, you might wana check the Wreckers for a new Cluster ..And take its Tacho.
    If you like, I can pull apart a cluster..And take some pics so you know how to Undo them and change the Gauges
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    VP SS
    Jan 2008
    Hiding in WA somewhere
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    Quote Originally Posted by excalibur View Post
    Quote Originally Posted by Verynice View Post
    nom nom nom
    yeah fair call guys.......
    dosent really help the poor guy though.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Sep 2009
    Default fixed
    cleaned all me spark plugs n put em back works perfectly now, n not miss fireing.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    VP SS
    Jan 2008
    If its got Wheels or Boobs its gonna cost ya money
  1. wiring up a taco to an ecu!
    By michael_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2009, 10:39 PM
  2. Tacho Not Taco!!!
    By PaRaDoX in forum Jokes/Humour
    Last Post: 05-10-2006, 11:02 AM
  3. VS Stato taco into VN
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 07:17 PM
  4. i like taco
    By chunderlicious in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2005, 10:58 PM
  5. taco
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 13-03-2005, 10:32 PM
Tags for this Thread
