Results 1 to 8 of 8
Thread: Power Window Drivers Door Problem!
    VN S Manual
    Jul 2009
    Default Power Window Drivers Door Problem!
    Ive recently been installing power windows in my vn commodore.
    The rear and passenger door's were easy, however im having problems with the driver's.
    When i had manual windows the drivers ould wind up to a point then the window would jump out slighty for half a turn, then being pushed back into line. It was never a problem as u could still wind the window up.
    Now that ive installed the power window reg and mounted it im having problems with the window going off the runners and dropping back, i also have lots of door flex in the inner skin. i tried all sort of adjustments and have had it in and out a dozen times but its not dixing the problem.
    The motor and reg are working perfectly, ive basically narrowed it down to something inside the door. but i have no idea what.
    Ive taken a video to try and show whats happening.
    If you could all check it out in would be awesome. will post it up in a second.
    VN S Manual
    Jul 2009
    having trouble uploading it, does anyone have any odeas just off the top of there heads?
    VN S Manual
    Jul 2009
    VN S Manual
    Jul 2009
    VN S Manual
    Jul 2009
    theres some videos,
    The last one shows a working pasenger window. we have done the exact same process for the drivers but im having that problem.
    please any ideas would help, really need to get it done!
    VS Berlina 3.8
    Dec 2008
    Did you manage to bolt the regulator into all four holes? When I did my drivers side regulator, I could only manage to align a combination of three holes, and it was doing a similar thing. I can't remember which three holes they were off the top of my head but I'll have a look. Also, make sure it is sitting inside the rails down inside the door. You can get a better look and feel of this by taking off that plastic sheeting that covers the door. Spring washers are also a good idea for this conversion if you aren't using them already.
    VN S Manual
    Jul 2009
    alright thanks for that ive go four bolts in it using spring washers, ill double check the rails part tomorrow but im sure its right.
    Its like theres something allowing the window to drop back, like somethings not holding it properly on th left hand of the glass looking at it from sitting in the drivers seat.
    VN S Manual
    Jul 2009
    come on guys! im really stuck on this ome!
  1. Vp Drivers door window off tracks
    By Cackyjack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2009, 08:13 AM
  2. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  3. [WA] WTB: VN VQ VP VR VS Drivers Power window switch
    By Chirpstr in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2008, 03:06 PM
  4. wtb - drivers door electric window motor
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 03-09-2008, 11:08 PM
  5. Drivers side window problem
    By onthepony in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2008, 07:03 PM
