G'day, to flush the whole brake system, is it necessary to bleed fluid from all 4 brake callipers? Or can I just bleed from one? I checked the how to section but couldn't find the answer. Cheers
yes bleed from all 4, it will clear out all the lines that way so the whole lot is fresh.
"A life lived in fear is a life half lived"
you can suck out most of the fluid in the resevoir and fill with new stuff, don't go below the holes inthe bottom. I use a syringe and that way you can suck the crud out of the bottom too. Also you need to bleed the caliper the furtherest from the master cylinder first and work your way back to closest (by lenght of tube).
Thanks guys, uve been a big help, now I can get on with it.
