hi guys,
ive just had a lot of transmission fluid leaking from bad radiator trans. hoses after i changed a rad. im geussing i should top up my transmission fluid, is there anything i should know about transmission fluid, can i top it up with any trans fluid or is it best not to mix fluids.....do i need to flush it if ive lost a lot anway....
thanks
It has to be at least Dexron III.
what does that mean, i should only use at least dexron III???
how much would a vn need to fill up on trans fluid, 1 litre do it?
dexron III & roughly 4 litres after a service refill, in your case i would check the level first top up accordingly and test drive. if the level is that low if will drive like S*** and be really noisy
where do you top up transmission fluid?
what happens if you overfill? its quite hard to gauge how high its gone, i put in 2 litres today and it was over the full mark
