Results 1 to 17 of 17
Thread: help black smoke
    vn ss 355, vl, vr, vs ss
    Jan 2010
    Default help black smoke
    hey all.
    when i first start my car it blow black smoke
    what could this b?
    Im having a Problem with my 1992 VP
    But, it wont start on first fire up anymore. It winds and winds.. If I dont use the Throttle a little, it will stall .
    BUT WHEN IT DOES!! A LOT of smoke black comes out, After 3-4 secs of that crap.. She runs fine, not a worry! not 2 good on Idle. If I turn the car off and start it back up within 5-10min it fires up one the 1st go. But any longer. It won't.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Check your Pod/Pannel filter... Might need a good clean!
    But, most likely.. It's your Spark Plugs, pull one out..If there all black n' dirty...there shot
    That's how I fixed mine when It did it
    Easy fix!
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Jan 2010
    it's a fair bit of smoke. n it dnt run right it ant missin just drop's revs
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Defiantly Spark plugs and maybe Spark Leads
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    fuel pressure reg, located on the left hand side of the fuel rail. My VN stoped kicking over first go and blew smoke till i chanegd it.
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    AHh.. woops. I didint notice the start up bit.. yep, fuel reg for sure.. I had that issue too..
    Jan 2010
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Yes I do-
    It sits on the Drive Side, behind the Fuel Rail,.. Very close to the Throttle Body
    You will need an Allen key..and Flat or Star screw diver
    Feb 2010
    facing the engine look to the left side fuel rail and you will see a small tin thing bolted on with two hoses coming out, one going under the car the other to the throttle body, take it off and swap for a new one or one from the wreckers and it will be sweet.
    Jan 2010
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Dont think so
    You need a VP series 1 or 2.. Which ever your engine is.
    AND! I recommend, buying it new.. Not a 2nd hand from the wreckers!
    Jan 2010
    how do u no if its a series 1 or 2? by the radiator hose? s1 go's down along the motor n s2 comes out the front?
    Jan 2010
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Quote Originally Posted by Dumster View Post
    ****You could pick one up from an Auto-parts store (supercheap/autobarn/repco/bursons/etc).
    VP seriesI and seriesII? Hmm, new to me.
    OP, yes a VN seriesI engine has the coolant pipe that runs down the drivers side along the top of the headers. (thermostat housing at the rear of the motor)
    SeriesII has the thermostat housing at the front of the motor
    VN/VP/VR seriesII fuel regs will ALL be the same.
    While your changing the reg, I'd give it a decent service too. (plugs, leads, fuel/oil and air filters, and clean or replace the TPS and IAC sensors while your at it)
    Cheers.
  15. #15
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Holden, told me.. You will need to show your VIN Number.. So you can get the right one.
    Seems odd.. but it works in my car..soo yeahh LOL
  16. #16
    Feb 2010
    I went down to the wreckers and pulled them out of VN and VP's till i found one that had a long tube at the bottom like Dumster's photo and it runs great, stuff spending $150 on that little tin thing, mine was free because i just stuck it in my pocket.
  17. #17
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Hahah nice.. i hope it was clean tho :P
    good work
    it took me ages to find that out.. No one on JC could figure it out
  1. Black Smoke
    By premium in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-10-2009, 09:38 PM
  2. black Smoke
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-01-2009, 12:21 PM
  3. Black smoke?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2006, 06:53 PM
  4. VR Puffing black smoke
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2006, 08:10 PM
  5. black smoke??
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-06-2005, 11:02 PM
