Hey everyone, I finally got round to installing my front power windows over the weekend. I have installed the drivers side window, but i'm having a problem with it. Whenever the key is switched to ignition, the window automatically lowers itself all the way down. Then I can only raise the window not lower it.
Power windows in the back are working fine, And module has been re - soldered by me a few months ago. The door open delay still works fine.
The power windows plug is wired to the Constant spot on the fuse panel in the right spot, using a Circuit breaker and the IGN wire is in the "power mirriors" spot (IGN) Is this right?
Help!!
All fixed now. Had a Faulty Power window module again. Swapped back to spare one, now hoping this one dosen't fail as well.
