Results 1 to 16 of 16
Thread: remove a heater box in a vp calais
    VQ V8 statesman
    Mar 2010
    bris
    Default remove a heater box in a vp calais
    hi my a/c/heater/blower/fan stopped working i think i have to take whole heater box out right??
    well i started it and made a big mess pulled dash out an all the bolts i can see now how do i get the a/c lines up top that goes to heater box out and is there anything eles??
    thanks in advance
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    You have to unbolt a flange in the engine-bay that surrounds the air-con hoses. You will also have to pull the plasttic cover off (whre the wipers are) and remove a few things from under there.
    VQ V8 statesman
    Mar 2010
    bris
    Quote Originally Posted by neet_wagon View Post
    where is the flange? and wipers and plastic is off and heater hoses and few bolts
    Jan 2010
    Bendigo, Victoria
    I haven't done one in awhile, but isnt there a cover that bolts to the firewall that the A/C pipes go through?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You have to disconnect the A/C pipe (ally tube) that runs through the top half of the fire wall and into the heater box at the top. (will need a re gas once pulled apart)
    Usre some crc around the rubber grommet that the copper tubes go thought (heater core).
    When all the bolts are undone the box will come out by lifting at the rear of the box and backwards at the same time. If you have the copper tubes lubed up it may just slip out.
    Took me a few hours on my own last time I did this. Just would not budge until the good old lube on the copper tubes
    and 3 Dangerous non ABS VN's
    VQ V8 statesman
    Mar 2010
    bris
    Quote Originally Posted by 88GreenVN View Post
    yeah how do u disconnect the a/c lines at the heater box
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by shreks vp View Post
    It's an alan head bolt into the top of the heater box - right next to the fan resistor
    VQ V8 statesman
    Mar 2010
    bris
    is that the bolt between the pipes outside the car where the wipers are?
    88GreenVN's Avatar
    Jun 2006
    Yep thats the one. Normally very tight
    VQ V8 statesman
    Mar 2010
    bris
    yeah it was tight the end of the alan key snapped off inside it now i gotta get that out some how GREAT well another job now
    88GreenVN's Avatar
    Jun 2006
    If you get the allan key bit out - give the top of the bolt a few hits with the hammer - gentle tho.
    VQ V8 statesman
    Mar 2010
    bris
    thanks got it out i hope putting it in and putting bits back together is easier
    88GreenVN's Avatar
    Jun 2006
    Saddly not I think. Getting the copper pipes thought the fire wall - can take 2 people to get it in quickly.
    VQ V8 statesman
    Mar 2010
    bris
    is a vr climate control heater box the same as a vp??
    and is any tips to putting it back in??
  15. #15
    VN WAGON
    Sep 2007
    my mate and i just did mine.
    vr climate box is diferent to a vn vp one. you need a vn vp or vq climate hvac box. and just be aware of flying hoses with coolent (wear googles) i found out the hard way
  16. #16
    VQ V8 statesman
    Mar 2010
    bris
    Quote Originally Posted by meanvn View Post
    whats the differents they look the same
  1. how do i remove a heater box in a vp calais
    By shreks vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-03-2010, 10:21 PM
  2. Vn calais heater
    By redlion05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2008, 06:34 PM
  3. WTB: VN calais Climate heater box
    By DumpedVT in forum Swap / Wanted to Buy / Trade
    Last Post: 10-12-2007, 09:33 AM
  4. heater not working in vp calais
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:45 PM
  5. Best way to remove heater hoses at firewall
    By commodore2004 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2006, 05:42 PM
