Hey guys, My vp v6 is missing real bad almost sounds like its running on 4 cyl. It was fine sat morning when i went to work but when i left work it was missing like a dog.
Anyone had this problem? Wouldnt mind hearing ppls thoughts on what it might be??
Cheers guys,
Daniel.![]()
mate go 2 dick smith or a shop like that or if u got 1 get your multimeter and check ur leads. i had the same prob my car was actually running on 4 cyl. plug ur multimeter cables in both ends of ur leads and check ur reading. i think u should set the multimeter on 2000 or 20000 ohms im not sure but the shorter leads shouldregester less like around 4-5 and the larger leads between about 6-8. mine ranged between 5 and 8. two of my leads regestered as ....... so yea got new set. but yea if that dnt fix it def ur plugs
hope i can help
Thanks guys, Plugs are only 3k old but il pull em out and have alook.
Is it possible that the fuel pump has dropped pressure?
Check ya plugs first, if there all black dirty, thats the problem! If not, then it could be Fuel Regulator issue, or Fuel pump..
But, im fairly certain its the Spark Plugs letting you down![]()
Ok plugs look fine, but 3 were loose. I snapped a lead trying to get it off lucky im getting new leads on sat.![]()
Sure was the leads, Now she starts easier and runs smooooth as.
Cheers for the help Dumster,
Daniel.
