+ Reply to Thread
Results 1 to 13 of 13
Thread: water temp gauge where 2
    VP Spack commodore
    Oct 2009
    gawler
    Default water temp gauge where 2
    hey guys people are telling me to install on the outlet pipe i was wondering if some1 can show me a pic so i know exact what im looking at and also what diameter is that pipe
    cheers if any1 can help
    2DIE's Avatar
    2DIE is offline 1 DOLLA HOLLA 2DIE Executive
    88 Calais
    Feb 2008
    South Aus
    Not too sure what you mean, if its what I think you mean its probably a temp gauge sensor? As for outlet pipe maybe they mean your water pump?
    Series 1 VN is will be at the back of the motor, series 2 will be at the front (at the other end of the radiator hoses).
    Still dont know if thats what you mean but I hope this helps.
    VP Spack commodore
    Oct 2009
    gawler
    ok you can buy water temp gauges and i want to put 1 on my vp 1992 i have been told to put it on the outlet pipe so its regestering the hot water coming out instead of the cooler water from the radiator goin in. i pressume buy water its coolant but i wasnt sure any ideas
    delcowizzid's Avatar
    delcowizzid is offline BAD COP! - NO DONUT!!! delcowizzid ClubSport delcowizzid ClubSport
    в∞ѕтεכ √&
    Jul 2008
    NZ
    put it in where the stock dash sender is at the back of the engine thats where mine is
    Quote Originally Posted by savage1987 View Post
    You're the reason I believe the youth of today are largely retarded.
    VP Spack commodore
    Oct 2009
    gawler
    any chance of a pic mate
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nah never took any its easy to find its brass with one wire going to it at the back of the inlet manifold under the elbow
    VP Spack commodore
    Oct 2009
    gawler
    any chance you can find me a pic of that i dont know what im looking for sorry mate
    в∞ѕтεכ √&
    Jul 2008
    NZ
    oh you have a vp its on the front under the alternator hard to miss once the alternator is off vn is at the back
    VP Spack commodore
    Oct 2009
    gawler
    what about this i thought this is what the water temp gauge should connect to
    Attached Thumbnails Attached Thumbnails water temp gauge where 2-01072009623-1.jpg
    в∞ѕтεכ √&
    Jul 2008
    NZ
    doesnt give you a true reading of the temp
    VP Spack commodore
    Oct 2009
    gawler
    ok i have noticed that you have helped others on kinda the same prob. i am lookin at after market sensor btw. also if i install as the pic above do you think i could do it without draining coolent
    в∞ѕтεכ √&
    Jul 2008
    NZ
    youll only loose a small amount just top it up with extra water.
    VP Spack commodore
    Oct 2009
    gawler
    so if i was to connect as of the pic above it would give me a general reading, but not accurate, btw what diameter is the pipe (top pipe vp comm). and if you have any other tips feel free to tell
+ Reply to Thread
  1. specometer water temp gauge!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 10:12 PM
  2. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-04-2009, 02:58 PM
  3. water temp a/m gauge
    By Mrute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2008, 11:13 PM
  4. water temp gauge
    By Billo55 in forum Electrical Wiring / Questions
    Last Post: 08-05-2007, 02:39 PM
  5. fitting water temp gauge
    By charged vp in forum Electrical Wiring / Questions
    Last Post: 10-03-2007, 12:08 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
