Results 1 to 5 of 5
Thread: VN fuel pick-up problem (?)
    VE SS
    Mar 2010
    Default VN fuel pick-up problem (?)
    Hi all,
    We have a problem with our Commodore when we go to start it. If the fuel level is below quarter full, and the car is parked on an angle sloping to the left (like normal street parking, sloping into the gutter), the car just won't start. If you push the car to flat ground, it will start like normal, and will run until the tank runs out of petrol. Similarly, if we keep the car on a slope but put 10 litres of fuel in it, it will start fine.
    We thought this might be a petrol tank problem to do with the float, so we replaced everything in the tank but the problem persists. We even replaced the whole tank, but it hasn't fixed it. We've been to at least three mechanics, still with no luck.
    We're not going to spend considerable money on this because it's not worth it anymore, but just wanted to know if it's something simple that we've overlooked, or if anyone has had the same issue.
    Can anyone help us?
    Thanks.
    vn ss
    Feb 2010
    hey mate i know uve replaced the tank but check the fuel return line going back into the tank is actually returning fuel into the swirl piot inside the tank...when a tank is low on fuel all remaining fuel surrounds the fuel pump in the swirl pot ensure pump is located correctly in swirl pot and return line fuel is dumping fuel in there corectly
    vn
    May 2010
    hi all,
    i have a problem with my vn , stalls or looses power for few seconds when i turn right, hard around a corner when im low on fuel , have to keep it over a 1/3. if it stalls normally starts straight away sometimes have to wait half hour. mechanics have changed fuel pump a few times and reg. it was loosing pressure. Is it the swirlpot??
    thinking bout getting another tank?
    Dec 2009
    It's either the fuel return not going into the swirl pot or the swirl pot may have come loose. Take out the fuel pump and sender and have a look inside the tank. When you put the sender and pump back in it has to be rotated as you insert it to make sure it is in properly, it won't just go in without doing this if the swirl pot is in the right place.
    vn
    May 2010
    cheers. just wondering where the return line comes from to get to the swirl pot? sender?
  1. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  2. fuel problem vr 5lt
    By craig vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2009, 04:44 PM
  3. fuel pick up
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 10:04 PM
  4. VB with LRP Fuel Problem
    By fergies in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-06-2005, 11:01 PM
  5. 89 VN Fuel Problem?
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2005, 09:04 PM
