vn series2 v6, had a blown head gasket this is how it was before i did the head gasket
1stcyl-150psi
3rd-150psi
5th-150psi
2nd-45psi
4th-0psi
6th-150psi
After
1stcyl-150psi
3rd-150psi
5th-150psi
2nd-150psi
4th-60psi
6th-150psi
Car does have rough ideal , Anyone got any ideas on what i can do next to fix replace etc
Real cars don't power the front wheels, they lift them
may have burnt valve in number 4 , is it choofing out the exhaust pipe or the inlet ?
sounds liek the exhaust, also noticed when i removed the spark plug it was not yet and didnt smell of fuel but the other did
carry out a cylinder leak down test and listen for air escaping thru the exhaust and intake , either way the head over number 4 pot will have to be removed and have the valves checked , did you have the heads shaved when doing the head gasket/s , pressure test the heads for cracks too
nope tryed to rush the jobguess that might have come back to bite me in the arse . how do i do a cylinder leak down test ?
leak down testing is used to check for loss from a cylinder via the rings but is also good for checking valves . remove the rocker gear allowing the valves to seat fully and apply compressed air to the given cylinder listen for air escaping thru exhaust pipe or intake also check for bubbles in the cooling system .
COOK COUNTY PERFORMANCE porting heads/manifolds & blueprinting. tuning by DELCOWIZZID
WANTED SV3800 headers for 34G, need stockers as made by HM headers ~ used with patina prefferable for scrutineering
when the cylinder is in the firing position the piston is in TDC applying air to the cylinder can cause the piston to move downs and rotate the engine moving the cam and opening the valves you which to check , there will always be a small amount of by blowby from the rings as they dont seal 100% , thats why a leak down test testes for percentage loss from each cylinder.
cheers guys will seek into it tomorrow at work and see how it turns out thanks
Well i checked the cyl and it held pressure ,so the piston/rings and bore is good, im wondering if maybe 1 of the valuves for the cyl might be bent or sumthing? or would my best bet now be the head is warped?
A bent valve would probably stick open or not move and break the rocker gear I'd think ? If it's holding pressure then the rings and valves should be OK?
might grab another head from the wreckers get it cleaned etc and see how that goes
