I replaced my extractors, but now my 02 sensor dosen't reach.Can i just make the wires longer? If so, what sort of wire do i need to use?
So the O2 sensors reached with your original extractors? You must have done something wrong...maybe put your O2 sensor in the wrong way? Or is it twisted or maybe the wire is stretched over something it shouldn't be?
If it fit the first time, it should fit the second time.......????
Follow Your Dreams......RIP Brocky 1945 - 2006......May God Rest Your Soul
If you undo the clips that hold the loom in place it should reach.
yeah try these suggestions first but if it still wont reach you can just extend the wires. just use a similar gauge (width) wire to the original and splice it in, make sure you use a high quality solder and heat shink plus shroud the wires in something heat resistant as obviously it gets hot down there
