Results 1 to 13 of 13
Thread: Removing the Dashboard From A Vp Commodore
    vp cxommordore
    Mar 2010
    Default Removing the Dashboard From A Vp Commodore
    Hey I have A Vp Commodore and I need to take out the dash board to rewire all the sterio and speaker wires cause i have no power in the power wires that connect to the stereo thanks heaps.
    vsspack's Avatar
    vsspack is offline King of the Mang
    VN Mang Machine
    Sep 2007
    Mildura
    Thats awesome dude. I have a toilet and i need to remove the resivour to replace the ball float casue i have no water coming into the toilet thanks heaps
    Some say less talk more action. But I rekon more torque less traction!
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    You don't need to take the dash out.
    You remove the centre console (I have to do this in my calais, I think the exec got a slightly different console where you just pop up the shifter surround), drop down the fuse panel cover under the steering wheel, remove glovebox and radio surround and thats it.
    vp cxommordore
    Mar 2010
    Default vp dashboard remove
    Ive Done all that what u said to do but the problem is i need to rewire the hole wiring audio system and all the wiring runs up into the dash board it might even be just a split wire or somfen simple but all the wire i can c isnt split ot anything so my only option is to remove the dashboard and c if there is anything in there that can cause the wires to have no power ive checked all the fuses under the steering wheel and there all fine do u no y it could have no power. It did have power on friday then i had to take it out and put the speakers in then i hooked it all back up and it had no power i tried a tester on the wires and they dont have any power at all.
    Feb 2004
    Where the mines are
    I'm trying to remember from when I put a head unit in my car years ago.
    Is it a aftermarket one?
    If so, check the fuse in the back of the head unit.
    Do you have the audio wiring diagram for the VP's? Its on here if you search for it.
    I would pull the plug out of the head unit and check with a multimeter to see if there is any power there.
    Edit - I just read you checked the wires. Did you do the ones at the loom that plugs into the head unit?
    vp cxommordore
    Mar 2010
    yer iF i hook it strait up to the battery it comes on and ive checked the fuse in the unit and its fine its deff the car wiring
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Have you checked the fuse in the power wire going to the HU.
    Visit my Facebook page
    vp cxommordore
    Mar 2010
    No Mate i havent checked that fuse the thing is is im only 18 its my 1st car and i dnt really no about cars thats well so i dunno wat the HU is or where it is lol
    VT S pack 5 speed manual
    Nov 2009
    The HU im assuming is the head unit. Your stereo lol.
    Did you check all the fuses? because there is also a fuse for the radio in the accessories section of fuses. Which deals with when you turn the key on.
    vp cxommordore
    Mar 2010
    Yer I did check the fuses there all fine in the HU and i also put a teaster on the wires that connect to the stereo and they have no power them selfs and they lead up into the dashboard somewhere so im kinda stuck on what to do like i can run 2 wires strait from the battery and use power that way but then it will kill the battery to quickly so cnt really do that lol
    vp cxommordore
    Mar 2010
    Have you ever had a problem like that where the power wires in the car have had no power? its wierd cause on friday it had power the to stereo power wires then they didnt 20 mins later so i cnt figure out whats happened to them.
    Jul 2008
    Do your self a favor and get a guy at autobarn to install it.
    Seriusly you have all the info you need in this thread. The nice thick yellow is power, there is allso an ignition interupt wire which you will need to connect aswell. big black one is the earth. GL
    vp cxommordore
    Mar 2010
    Thanks heaps mate for all your help.
  1. Removing parcel shelf and dashboard?
    By cruzncommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 11:23 AM
  2. Help Dashboard Removel Vl Commodore
    By CACTUS_13 in forum General
    Last Post: 02-12-2005, 10:40 AM
  3. Removing The Dashboard
    By jem in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 07:15 AM
  4. removing dashboard VK
    By dcanna in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2005, 07:31 PM
  5. Removing Dash Cluster Out Of Dashboard?
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2004, 10:21 PM
