Results 1 to 9 of 9
Thread: Dead fuel pump or something else?
    meme865 is offline VN 5speed manual v6
    VN Executive S2
    Feb 2009
    Unhappy Dead fuel pump or something else?
    Hey guys, i got a S2 vn. it had been sitting for a lil while, and i go to start it but she was out of fuel, anyways i got some fuel filled it up and tried starting, she started for about 5-10mins and then died.... and it wouldnt start again. it will start randomly and once again stop like 5-10mins later then wont start. is it my fuel pump or something like that? i can hear the fuel pump start up when i turn the key and after it stops.. so yea.. help please? =)
    Cheers.
    1992 VP vacationer
    Nov 2009
    well thats normal for the pump to run for a few seconds after turning on the ignition as the pump only runs for that few secs to pressurize the line. hear if it runs while the car is running. put your ear under the tank and listen while the engine is running. tell me what happens
    VP Ute
    Jan 2009
    Willowbank Qld
    VN Executive S2
    Feb 2009
    iv changed the filter. car still isnt starting. but if it starts ill have a listen, but if its running then the pump must be working right? just around like 10mins it dies. weird right?
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Sounds like CAS to me, if the car heats up and stops. If you do getting it running again wait tell it stops and throw some water on the CAS and see if it then starts. I think thats how you test it? I havent done it before someone else can verify.
    Try changing your EFI relay, ive had it fail on me before
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VN Executive S2
    Feb 2009
    I put water over the CAS once it stopped, and it didnt start. i changed the EFI relay over and still nothing. anymore ideas?
    VN Series 1 S-Pack
    Feb 2010
    Sydney, NSW
    Check if the car has spark when it wont re-start.
    If it does not have spark then check the DFI Module. You should also be able to check it for codes. If the ECU is not getting a signal from the CAS, then it should log a code.
    Once it cuts out, pour water on the edge of the coil pack near the alternator until the underside of the coil is cool. Leave it for about a minunte or 2 and try to start it. Just did mine as it cut out in the middle of a main road and wouldn't re-start for an hour.
    VN Executive S2
    Feb 2009
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
  1. fuel pump possibly dead ?
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2009, 08:53 PM
  2. Fuel pump dead, need help with lpg...
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2008, 12:18 AM
  3. VP 5litre running bad, dead fuel pump?
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2007, 08:48 AM
  4. Fuel pump dead????
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2007, 12:55 PM
  5. Dead fuel and temp gauges
    By -VnExEc- in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 01:20 PM
Tags for this Thread
