I've just dropped an Ecotec into my VN. I've taken the motor and Getrag box from a VS and slipped it in. VS pedal box and hydraulic clutch. No problems in that area when you have a complete donor car. I know this has been covered before, but I'm still a liitle unclear about a few things. I believe the firing order is different and needs a couple of plug leads swapped over, which ones and still a liitle unsure of the coolant sensor situation. Also can I get the Getrag speedo sensor to work. Using VS loom and VN computer.
