Results 1 to 9 of 9
Thread: Every 1 Who Has This Problem Try This!
    JohnyRock's Avatar
    JohnyRock is offline Live Long Rock Hard!
    VX Executive (V6)
    Mar 2010
    Newcastle
    Default Every 1 Who Has This Problem Try This!
    Ok Vn Commdores And Tail Lights Spells Trouble!
    Here Was My Problem
    Head Light/ tail lights On, Fine - Foot On Brake Whilst Head Lights/ tail lights are on Are On Right Side goes Out... + bottom tail lights never worked.
    I rang up auto elec's and got qoates and they wanted to charge upwards of $100 to fix this
    they told me all sorts of stuff from earth problems to power source problems to wiring!
    Now heres how i fixed that plus more with $10! no shit!
    Went to the wreckers and got a new tail light harness from a wrecked vn, got home pluged it in to see if it all works (the blinker was the only thing that didnt work)
    So..
    i cut the brake 1 of and cut the 1 of that was on my car and wired the 1 from the wreckers up! tail light/ brake light problem solved..
    now the bottom lights never worked for me when i put my tail lights on
    so..
    i got some sand paper and cleaned the conection on my driver side and it works fine now..
    as for the left side it was F#$ked!!! so i cut another harness off the 1 i got from the wreckers and wired it up in place of the shit 1 and now all of my lights in the rear end work with out a problem!
    I suggest You Try This Before Paying through The Neck For Something That Maybe Cheap To Fix!
    Also Im Sorry If My Jargon Is Not Correct im Not Very Mechenical Minded!
    In My Words
    Harness = the cable with all the plugs for the light globes on it!
    Nearing The Completion Of My Vt!
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    They must of been petty bad to need new ones! I just sand back and re-solder the contacts.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    JohnyRock's Avatar
    VX Executive (V6)
    Mar 2010
    Newcastle
    Well the bottom tail light on the right was rusted to the shit house! i had to break it all away to get the bulb out.. and as for the 1 on the left i just sanded it and it worked fine, but the tail light on the drivers side i dunno why it didnt work coz it was rusty and the wiring was fine but it didnt wanna work untill i wired up the new 1..
  4. Default
    yeah i had the same thing with my vp, the sockets were absolutely corroded to shit! down at the wreckers i got 2 looms for $10 each, and the right hand side one was new so i was happy about that
    Quote Originally Posted by zai View Post
    I am not sutpid
    JohnyRock's Avatar
    VX Executive (V6)
    Mar 2010
    Newcastle
    Man i cant beleive i was about to fork out the $$$ and it was that cheap and easy to fix! and i hear people talking about it all the time..
    thought id post to try and save them some cash and if it dnt fix there prob it was only up to $10 spent.. im glad all my lights are working now!
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    or u can just buy the new harnesses from holden cheap as... i went new.. but im sure out of a wreck is just as good
    VN S1 (was VR) V6 Hilux
    Apr 2009
    All I can say is - "When I was a Virgin DIY repair my own car owner, I got the same warm and fuzzy feelings too!" - when I did stuff myself. Nearly 30 years later, the feeling never stops because I just keep on doing it myself!
    Now i have given it a few more seconds of thought, I'll admit I can't wash a car or apply tyre black for sh!t like a real "car enthusiast" can, but I have no problems replacing a clutch or piston rings! I'll just leave it to the real enthusiasts to wipe the grease of the panels when I'm finished!
    JohnyRock's Avatar
    VX Executive (V6)
    Mar 2010
    Newcastle
    Quote Originally Posted by Vt-Brrrlina View Post
    Yer im thinking about still going to holden and getting a new harness for both sides! but only when i got the spare cash, i wanna replace as much stuff as i possibly can on the car and make it all new coz i plan on keeping her for a while!
    VP Executive & VZ Adventra V6
    Sep 2006
    I had similar problems with my VP. After replacing the harnesses (because a few of them were completely rusted through), my bro and I put greese in each socket to coat the metal and prevent it from rusting. I haven't had any problems with the rears for over 10 years now and no rust has returned. I think at the time I paid $22 for the replacement harnesses. Always check with Holden first how much replacement parts are, sometimes they are just as cheap to buy the new genuine part.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. problem with my VP
    By hoodlum1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 04:13 PM
  5. got a gas problem help
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2005, 10:25 PM
