Results 1 to 5 of 5
Thread: Will a series 2 VP manual fit in a series 1 VN?
    1994 VN Commodore
    Sep 2009
    Default Will a series 2 VP manual fit in a series 1 VN?
    I'm thinking about buying a series 2 VP for $500 so that I can put the manual transmission into my VN, but I'm not sure if there's anything that might not work.
    Anyone know if this will work?
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Check this thread,
    The complete Vn-Vr Manual Conversion Guide.
    Theres some info in both my ride threads about manual conversions as well (links below)
    If its a V8 i belive it will be fine, if its a V6 well read this as well,
    V6 Crankshaft Info
    edit: 1994 vn?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    1994 VN Commodore
    Sep 2009
    It's a V6 auto VN, so judging from that thread I'd need a crankshaft adapter and maybe a new computer for the VP if I wanted to keep it running.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Would prob be easier and better if you just dropped the engine and gearbox into your vn.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VN S1 (was VR) V6 Hilux
    Apr 2009
    Quote Originally Posted by athzhr View Post
    I just put a S1 auto engine in front of a manual. You will need the adapter and you will not need the new computer, as they are the same - VN-VP Auto Manual.
    If you change the whole engine to VP, you will also need the different radiator and overflow bottle setup instead of the VN S1 header tank.
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. vy series II ute manual
    By ERDEM_CIMBOM in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-12-2009, 03:02 PM
  3. VS Series 3 Ute....>>>>T5 Manual...
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2009, 12:19 AM
  4. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
  5. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
