Results 1 to 5 of 5
Thread: Clutch pedal height
    Sep 2004
    Default Clutch pedal height
    The clutch pedal on my vn ss sits about an inch above the brake pedal and seems to have a long way to travel to the ground which makes quick take offs hard
    it also grinds into reverse which is a PITA not sure if that's an adjustment problem though
    does the pedal height and travel sound normal how can I go about making it better?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Mine, (In a V6 maunal), sit's about level to the brake pedal, but all of my clutch play is in the first inch or two of travel.
    So with mine, if I'm playing around, trying to save time in shifts, I won't even put the clutch to the floor.
    BTW....My reverse crunches too...It always has....For years.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    Jun 2005
    mine sits about level with the brake pedal. easy to adjust it under the car
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Sep 2004
    Only thing that's annoying me is the box has just had a pretty expensive rebuild and strengthening (through a very reputable garage) and a half button clutch...
    Was just expecting better
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    It will grind in reverse if you havent stoped or had it in netural and quickly went to change it to reverse. In that case shift to 5th first then to reverse and it will stop or just wait a bit before putting it into reverse. Reverse dosent have synchros so you need to be stop aswell as the gearbox, cause as soon as u push in the clutch the gearbox dosent stop spinning stright away. Putting it in 5th first uses its synchros to slow/stop the input shaft rotating.
    My clutch pedal is just above the brake and thats set according to the manual.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  1. clutch pedal vibration
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2010, 10:21 AM
  2. Clutch pedal loose
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 10:19 PM
  3. t5 clutch pedal again
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 07:28 PM
  4. Wtb:vs Clutch Pedal
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 25-11-2007, 12:43 PM
  5. squeaky clutch pedal
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 09:26 AM
